Thread: White algae (I guess) on floor of pool. Safe to swim?
    All levels are good. Pool turned green on me last week. Got it slammed, now it's sparkly blue with what I guess is dead white algae on the floor. Can the kids swim in it?
    20000 gal inground vinyl liner, HTH 6 Way test with Taylor FAS-DPD for CL, Dolphin DX4 Cleaner
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: White algae (I guess) on floor of pool. Safe to swim?
    Need to post some numbers.
    Your idea of good might not be the same as mine but if they are good than I'd say vac the pool and then sweep to get that stuff brushed up so the filter can grab it and let the kids help by swimming and splashing about as they normally do
    Solar Blanket, Well Water, Borax Added. 76
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    The white stuff is probably dead bleached algae carcasses, or sand, or dust, or DE or something else inert. Vacuum it up before they stir things up and make it look cloudy. I doubt it's toxic.
    As for safe... depends on what "all levels are good" means. If the pH is between 7.2 and 7.8 and the FC level is below shock level for your CYA, then let 'em in.
    Casey's Avatar
    SW PA
    10,461
    Lets see some numbers...
