Results 1 to 9 of 9
Thread: I Enjoyed the TFP Method So Much That...
    SPKNout4CHRIST's Avatar
    Mar 2011
    Goldsboro, NC
    210
    ...I decided to let the pool get green and do it again! Actually, that is not how it happened, but it happened. I let my salt level get too low while out of town for 2 weeks and came home to a nice green pool since the SWG stopped running . Whoops.
    Seeing as how I went through the TFP method a few years back when we moved to this house, I am certain it will be back up and running in no time. I have checked my levels and have added the bleach needed. I just wanted to document the progress as it clears up and hopefully encourage others out there experiencing this for the first time that this CAN be done! I added the bleach about 15 minutes ago, so stay tuned as we see the TFP method do its thing!
    God bless and enjoy!
    Matthew
    22,600 gal. Vinyl Inground, FNS Plus 60 DE Filter, WhisperFlo 1HP Pump, SWG, Dolphin Nautilus
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: I Enjoyed the TFP Method So Much That...
    That's quite fluorescent! Does it glow in the dark, too?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Subscribing....love to watch the green to cleans!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Please post your tests as this is a wonderful show and tell for new people as you already know what you are doing and what you're up against.
    Solar Blanket, Well Water, Borax Added. 76
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    JELLO!!!!!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mar 2011
    Goldsboro, NC
    210
    First results and progress pics are in! 4 hours after starting the SLAM process, we can see progress. The bottom is visible in the shallow end and the bright green color is diminishing. You can see pockets of the bright green, but most has turned to a pale green or white color. My test results so far are below.
    My pH is reading high (around 8), but I am attributing that to the status of the pool and will re-test that once it is cleared up. I haven't added CYA or tested it in a while and can tell that I need to get some in there to hold my chlorine during the day. I think I still have some from last time, so I will be adding that ASAP. I added enough clorox to keep it just above shock level for the rest of the day and into the night. I will check it again first thing tomorrow and make sure to keep it up during the day to ensure it doesn't get too low.
    Initial Test:
    FC = 0
    CC = 0 (I am not sure why this tested 0 as I know this cannot be true - tested it twice with same result)
    pH = 8
    CYA = 0 (I am sure this is right as this has not been added in a while and nothing added to the pool that would add any. I have had several "filter to waste" sessions because of rain water, so I assume this has diluted it over time.)
    Test #2 - 4 hours later:
    FC = 10 (shock level for my pool with 0 CYA)
    CC = 0.5 (Still wondering why this is so low, but will keep SLAM'ing anyway as I know there is something going on.)
    Richard320's Avatar
    Jan 2010
    19,074
    Just for you
    Mar 2011
    Goldsboro, NC
    210
    Haha that is awesome and pretty much sums up my reaction!!
    Casey's Avatar
    SW PA
    10,461
    You're going to blow through that SLAM with the DE filter!
