Results 1 to 9 of 9
Thread: kalljo, New to TFP, Hi All (no rsvp requested)
    Jul 2014
    Fuquay Varina, North Carolina
    3
    We have recently purchased and have had mostly installed a 28 by 15 foot, 18,000 gal. fiberglass (Hampton style) swimming pool. I say partially installed because after a month and a half I gave the installing company their final check and sent them on their way.
    This is our second pool and our first inground saltwater system.
    We relied heavily on our local pool store the first time around but after having similar complaints and results as other customers we have decided to go it on our own, with of course little help from our friends, we hope, on this wonderful site we found "www.troublefreePool.com".
    We will go to Pool School and hopefully post relevant questions and not appear to ignorant in the posting process.
    Thanks to all contributors for what appears to be a great pool owners resource.
    (PS I haven't figured out how to add my pool demographics to signature yet, sorry)
    Re: kalljo, New to TFP, Hi All (no rsvp requested)
    Welcome to TFP!
    To edit signature: press "Settings" (just below the Pool School button near the top right), then pick Edit Signature on the left side.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Welcome!
    How to fill out your signature is here: http://www.troublefreepool.com/conte...efore-you-post
    If you get nothing else out of this forum, get that you need your own proper test kit. And you probably won't find what you need in stock locally. The DPD test kit they will try to sell you is not the same as a FAS-DPD test kit you need.
    You can even support your state's economy by just getting what you need here: http://tftestkits.net/TF-100-Test-Kit-p4.html
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    We'd love to see some pics of the pool
    You're done SLAMing when:
    Jul 2014
    3
    Thanks, managed to find and create signature, hope it's correct
    Kalljo
    Pool installed 6/10/14, Hampton Fiberglass Pool 13,200 gal 392 sqft, Pentair SuperFlo SF-N1 340039 pump, Pentair Sand Dollar Pool Filter SD80 145333, Pentair IC20 IntelliChlor Salt Chlorinator, TF-100 Test Kit, Borates Test Strips, Taylor K-1766 Salt Test, Zodiac Baracuda G3 cleaner
    Casey's Avatar
    SW PA
    10,457
    Looks good! Now we need pics of the Hampton Pool you speak of!
    Welcome to TFP!!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Jul 2014
    3
    Photo Progression
    Pool in the ground
    http://i1352.photobucket.com/albums/...ps8a5b5da4.jpg
    Built a raw rock wall in slopping front yard. used dirt to level front yard
    http://i1352.photobucket.com/albums/...ps03a4b370.jpg
    http://i1352.photobucket.com/albums/...psedcab383.jpg
    planted grass
    http://i1352.photobucket.com/albums/...ps7b4d0520.jpg
    built steps from house to pool
    http://i1352.photobucket.com/albums/...psbced6b6f.jpg
    added concrete then covered with coping and 2ft walk around pool
    http://i1352.photobucket.com/albums/...ps6277d418.jpg
    prepare area around pool for sun space and pool patio
    http://i1352.photobucket.com/albums/...psfab9541e.jpg
    started laying more pavers
    http://i1352.photobucket.com/albums/...psdd8b92a9.jpg
    Iro is patiently waiting for rest of pavers, retaining wall and fence, etc.
    http://i1352.photobucket.com/albums/...psd153abc9.jpg
    Thanks for photobucket info, works well
    Kalljo
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by kalljo View Post
    Photo Progression
    Pool in the ground
    planted grass
    Trying something... Switched url to IMG and walaaaaa! Pics on forum!
    Great looking pool and I love Iro!
