Results 1 to 10 of 10
Thread: TA way high.
    TA way high.
    My ta tested at 400. Um. I been fighting this year however It has jumped. Whath causes TA to jump like that. My ph did test at 7.5
    18,000g 27' x 52" AG, Proline cartridge filter, 1.5hp pump, ChlorEase CL02 chlorinator
    pool is a transplant from one location to my location and was just put up 4/5/13
    Location : Delaware its on the EAST COAST and yes its a state LOL!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: TA way high.
    Testing error? Wrong sample size/wrong reagent? Static electricity on the tip of the R-009?
    Have you added anything out of the ordinary to the pool? Borax, Soda ash, Baking Soda, some all-in-one product?
    Has it been creeping up weekly, or just all the sudden?
    Re: TA way high.
    Sudden. I tested twice. Have been using acid alot. Cleaned my swg its working. Altho salt was low.
    Im increasing salt but stopped at 3600ppm when I noticed TA was way high. Everything else is in check but TA and salt a bit lower then I had last year
    Richard320's Avatar
    Jan 2010
    19,037
    Re: TA way high.
    What's the TA in your fill water? Maybe they switched sources?
    Re: TA way high.
    Didnt think of that. I had over filled pool when was low had to drain some. Now you say that the TA has been high about since then. I will test it tonight if I have time after work.
    I still have to drop the level. Thats a LOT of acid to get it down.
    Jul 2014
    Berks County, PA
    206
    Re: TA way high.
    Be patient...I just went through this with new fill water. Gradually keeping the pH down will also bring the TA in range.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Re: TA way high.
    I hit it with acid. Airrated TA on point. Now adjusting ph. Fill water was high TA.
    Jul 2014
    Berks County, PA
    206
    Re: TA way high.
    Same here...my fill water had a pH OVER 8.8 ! It took aLOT of acid to get things under control.
    Robert.wolfe's Avatar
    Jul 2014
    Dallas, tx
    25
    Re: TA way high.
    I had a problem with a pool filled with well water. I had to hit it with 16 gallons of acid to finally break the 400 mark.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: TA way high.
    Welcome to TFP!
    Yes, some well water is quite high in Total Alkalinity (TA) and often also in Calcium Hardness (CH).
