Thread: Circupool reading check cell
    Oct 2013
    Baton Rouge, LA
    86
    My circupool si system which is about 4 months old is reading check cell? Does anyone know what to do for this? Water is balanced well and salt level is 3400.
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    Re: Circupool reading check cell
    Take the cell out and visually examine the cell plates. If you see any white crusty stuff you should clean the cell and adjust your levels so calcium scaling won't continue happening.
    If that isn't it, post back and we can come up with some other things to check.
    Oct 2013
    Baton Rouge, LA
    86
    Thanks, I'll do it now. Also I'm adding stabilizer with granules and a sock in the skimmer. Is it ok to run the swg while the stabilizer is dissolving? What should I use to clean the cell plates?
    Oct 2013
    Chapin, SC
    1,141
    Yes, it's perfectly fine to do that-- I did! 1 part muriatic acid to 4 parts water. Instruction should be in your owner's manual. Page 16 in mine.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
