Thread: Calcite Saturation Index
    Curtsam's Avatar
    Aug 2013
    Eastern Oklahoma / Arkansas
    33
    Everything in my pool seems to be adjusted well except I am having a very low CSI reading of -1.23.
    Temp- 86
    FC- 5.5
    TC- 6
    PH- 7.5
    TA- 60
    CH- 40
    CYA- 60
    Salt 3400
    Please let me know if the CSI is important enough to get in range and how the **** to get it there. Been looking at exisisting posts and can't find the answer.
    Thank you All for EVERYTHING on Here.
    Sam
    2014, IG 20,000 gl 18x34 Vinyl Liner / Waterfall / SWG / Sand Filter /
    Dolphin M4 Robot / TF-100 Test Kit is used / Beer is consumed /
    *Stamped Concrete Decking*
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Calcite Saturation Index
    You can use Pool Math to see how to get there. Put in higher values of CH and TA and see what you come up with.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Just noticed you have a vinyl liner. I see on PoolMath that low CSI doesn't seem to be a problem for vinyl.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Low CSI doesn't matter in a vinyl pool. There's no plaster to etch. High CSI could still become a problem, so be grateful you have such soft water!
    30,426
    In all but the most rare cases, caluolation of CSI is not a mandatory process of teting pool water.
    read "The ABC's of Pool Water Chemistry" up in Pool School......read those ranges carefully. Now, stay within the suggested ranges and CSI becomes irrelevant.
    Take your regular tests out side the normal parameters and CSI can be very troublesome.
    I have never test CSI in 9 years.
