Results 1 to 11 of 11
Thread: Question about multi-port valve...do I need
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    A valve on my waste port?
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Question about multi-port valve...do I need
    People add valves to the waste line as a band aid fix for a leaky multiport. You don't need one.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by JohnT
    Hmmm...I think I have a bad multi-port then
    Is water supposed to come out of the waste port when I move the valve to all the different positions?
    It doesn't expel water out of the waste port on filter mode though
    I'm gonna go mess around with it some more and get more details.
    Thank you TFP
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    OK...
    These are the positions where water flows out of the waste port.
    Rinse
    Backwash
    Waste
    Winter
    Do I need a spider gasket?
    It looks fine
    I'm using This diagram and parts list to make sure it's put together right
    Thank you TFP
    SW Indiana
    9,199
    Quote Originally Posted by Crzyfrlss1
    OK...
    Rinse
    Backwash
    Waste
    Winter
    It looks fine
    Water should come out the waste line on those settings, but Winter is not designed for pump operation. As long as it doesn't come out during filter or recirculate, you have no problems.
    Waste flushes excess pool water to the waste line. Backwash runs water through the filter backwards and out the waste line. Rinse runs water through the filter like normal, but sends it out the waste line instead of back to the pool.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Thank you John
    So this means there is nothing wrong with the valve then?
    This is my first experience with a sand filter and the equipment didn't come with any paperwork so I wasn't sure about alot of things
    Thank you TFP
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    It sounds like its working properly.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Thanks John and Molson
    I needed assurance that this was normal or not.
    Thank you TFP
    Mar 2007
    Coastalish 'down easter'
    4,160
    I just want to add that when you change multiport positions, all the ports open, so it's 100% normal to see a little water come out of the backwash port, as long as it stops when the pump is on filter-- all is good
    Luv& Luk
    -Ted
    Butterfly's Avatar
    South Carolina
    10,045
    You may also want to Google a copy of the owner's manual.
    You're done SLAMing when:
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by Butterfly
    I tried that already
    The only thing I could find was a parts diagram from Astral Pool.
    I suppose a parts diagram is better than nothing at all though
    But all is well now and I thank all who have contributed to this matter
    Thank you TFP
