Results 1 to 9 of 9
Thread: Need some help...
    May 2014
    Louisville, KY
    30
    Need some help...
    Was away for a while (vacation) and came back to an issue. We had a yellowish looking substance collecting on the shady side of the pool between the floor and the wall. It was also in patches on the bottom of the pool. When I brushed it, it just looked like powder and disappeared only to be back in an hour or two. I noticed there was some of it clinging to the walls so I figured it was mustard algae.
    I slammed the pool for a day and a half mustard shock level, adding bleach every two hours. The next night it was gone, did an ONLT and did not loose anything.
    Yesterday, noticed some stuff on the floor only, more of a grayish color. Vaccumed it out, took out the cartridge filter and cleaned it and did another ONLT last night only loosing 0.2.
    This morning, the same stuff is on the floor again. I am going crazy!
    We have had problems with pollen all year (live in the country by woods and two fields that are bailed often). I am not sure if it is that, or dead algae that is settling on the floor. Any ideas?
    Current #'s:
    FC 8.8
    CC 0.0
    PH 7.7
    TA 120
    CH 130
    CYA 45
    21x43 Above Ground Vinyl, Hayward Voyager Cartridge Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Need some help...
    I would bet on a combination of dead algae and pollen.
    30,421
    read "SLAM" in the "How To" section up in Pool School. To stop the SLAM, you need.......
    1. Your pool water is sparkling
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    1. Your pool water has never been clean for any period of time so #1 is a failure.
    2. Looks like you passed the CC's test
    3. What FC did you start with when you began the OCLT.....what time of day was it?
    What FC did you end with when you tested again the next morning. What time of day was it?
    I think if you will re-read the SLAM process and follow it to a a T, your water will clear.
    May 2014
    Louisville, KY
    30
    Started 21.5. Ended. 21.5
    Casey's Avatar
    SW PA
    10,446
    That definitely looks like dead algae mich7088.
    May 2014
    Louisville, KY
    30
    OK thanks! Apparently I forgot to say the water is completely clear and "sparkling" which it is.
    The other thing I was wondering is should I keep it at a higher FC level now that it has had this type of algae to try and make sure it doesn't return? I have it at 6 now.
    Apr 2010
    East Texas
    9,609
    You never listed a reading for CYA. Won't hurt a thing to hold it a couple points higher above minimum for whatever that number is according to the chlorine/cya chart in pool school.
    May 2014
    Louisville, KY
    30
    Cya is 45
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Need some help...
    Also, the procedure for mustard algae states that, once you pass the 3 tests for SLAM you need to raise FC to mustard algae level for an ADDITIONAL 24 hours.
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
