Thread: Ok to use chlorine neutralizer?
    Oct 2010
    michigan
    284
    Just got back from vacation, i shocked it and put mesh pool cover on, back after 12 days, chlorine thru the roof. is there any side effects of chlorine neutralizer?
    having a pool party in 2 days, need to lower it.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    38,371
    Re: Ok to use chlorine neutralizer?
    Why do you think you need to lower it? What are your CYA and FC levels?
    Oct 2010
    michigan
    284
    Cya 45 to my eyes and 50 to my wifes eyes, lol
    Fc. Is at 16, actually the party is tommorow.
    Just swim and dont worry about it?
    Jul 2013
    Gilbert, Az
    116
    it is safe to swim up to shock level
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    IF ... your CYA was down to 40 you'd still be OK to swim at 16ppm FC but it might be a little irritating to your guests.
    If you do add a neutralizer I'd wait till a couple hours before the party to see where it's come down to as it's always nice to be a little high before a party. You know "they" will be using some up and you might not need to lower it.
    Solar Blanket, Well Water, Borax Added. 68
    With 24 hours to go, the FC level will come down quite a bit on it's own. I don't see any reason a chlorine neutralizer could possibly be needed.
