Thread: Polaris Booster Pump - Repurpose as a Pool Dain Pump?
    jimsky's Avatar
    May 2014
    Long Island, NY
    60
    This season I dumped my old Polaris for a Dolphin Nautilus, I'm happy with the decision. I tossed the old rickety Polaris bot but kept the 3/4 HP booster pump, thinking it could possibly be used as a pool drainage pump. I rewired it for 115Vac and gave it a try tonight, just would not prime. I put the inlet hose up to a pool return forcing water into the pump...it finally started pumping. The second I removed the inlet hose from the return and dropped it in the pool, the water flow stopped.
    The booster pump sure worked well when it was being forced water from my main filter pump in the original Polaris setup. I guess this type of pump can't self prime and continue moving water unless it is pressure fed?
    19,200 Vinyl IG, Hayward 1HP Super Pump, Hayward DE-2400 Filter, Stenner 45MHP10 with 15 gallon tank, Dolphin Nautilus, Roof Mounted SunGrabber Solar Panels with separate 3/4HP pump and self-designed solar pump controller. Stand alone 4 person MasterSpa hot tub.
    Re: Polaris Booster Pump - Repurpose as a Pool Dain Pump?
    That pump is designed specifically to be fed water and operate at high pressure out of the pump. The setup you describe would not be a good use of the pump.
    If you increased the backpressure out of the pump, you might be able to get it to operate once you got it primed. However, you risk damaging the pump.
    It also does not have a strainer pot, and any debris would quickly clog the impeller.
    Support the site
    jimsky's Avatar
    May 2014
    Long Island, NY
    60
    Thanks for the confirmation, to the curb it goes.
