Thread: Cartridge filter leak where pressure gauge is located
    So lately, I've been getting more and more bubbles at start-up. Today I found a air leak when the pump is turned OFF right where the pressure gauge is at.
    I'm going to have my tech look at it this weekend, but until then, should I run the pump continuously? I don't want it to get so bad where the pump starts up dry and maybe cause damage.
    ~12k gallon, cartridge filter, IG, plaster, 2hp Pentair Whisperflo WF-28, 150gpm filter
    Pics: http://imgur.com/a/HqaPq#0
    Re: Cartridge filter leak where pressure gauge is located
    A pressure side leak could cause the pump to lose prime when it is off, but the pump should be able to re-prime it's self when it starts up again. If you have actually seen the pump run dry, then yes, leave it running. But that seems unlikely to me.
