Results 1 to 19 of 19
Thread: SLAM- skimmer and return plastic turned orange
    Jul 2014
    St. Louis
    15
    I've started to SLAM our pool I've currently reached FC 7, and noticed that the plastic skimmer and return port have changed from white to orange. When I rotated the return port and revealed plastic that had not been out in the open, it was white. Does anyone know what is happening and is this permanent?
    The pool water itself is a hazy blue/green and a lot of white fluff had appeared on the walls overnight.
    Thanks!
    8500 gal, AG, 150lb sand filter. Free with house purchase.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: SLAM- skimmer and return plastic turned orange
    Could it be metal staining?
    Casey's Avatar
    SW PA
    10,438
    It could be metal staining. What is your fill source?
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Welcome to TFP!! Do you have some Test Results?? Pics?? It could be your fill source??? Need more info!
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Jul 2014
    St. Louis
    15
    Our fill source is the hose attached to the house. I don't believe it is high in metals, but don't know for sure.
    When we began SLAM 2 days ago:
    FC 0.2
    CC 0.2
    pH 7.3
    TA = 120
    CH = 60
    CYA = 34
    At 8pm tonight FC 6
    Added Chlorine (miscommunicated and added 150oz 8.25% instead of 90)
    At 10:15 I checked, and FC was 16.
    I read about taking a vitamin C tablet and pushing it against the plastic to see if it is metals. Might try that tomorrow.
    Jul 2014
    St. Louis
    15
    Yall were right, it is metal staining. I took a multivitamin and set it on top of the plastic return outlet. The vitamin immediately started bubbling, and I could watch the orange color dissolve away. Pretty amazing , thanks!
    Jul 2014
    St. Louis
    15
    Current picture of our 'Green Swamp'
    Casey's Avatar
    SW PA
    10,438
    So lets clear the pool by SLAM'ing and once we get it clear, we can work on treating the metal staining. You ready to do this?
    What test kit do you have?
    Jul 2014
    St. Louis
    15
    Ive been ready to go swimming since June. Just realized it wasnt going to happen taking the pool store's advice.
    I have the Taylor FAS-DPD K-2006. So far I have gone through ~7 gallons of Clorox!
    Just tested, I think this is a good place to end the night, right?
    FC 12.5
    pH 7.4
    CYA 32
    Jul 2014
    St. Louis
    15
    This morning FC was at 8
    To reach 13, the calculator says I should add 64oz Clorox. I was wondering though, would it be bad to add say 100oz since I apparently am not close at all to neutralizing everything in the pool?
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    I would advise you to check "effects of adding chemicals" at the bottom of PoolMath.
    100oz of 8.25% would raise your FC by 7.8, bringing FC to ~16.
    Jul 2014
    St. Louis
    15
    Right, but so far the FC might get to my target SLAM FC temporarily, but always goes down due to who-knows-what is in the pool.
    So I wondered if I added more Clorox than the calculator calls for, if the FC drop 8 hours later would be less.
    When we bought the house, the pool cover was about 5 inches underwater and it was a bird and squirrel sanctuary/watering hole. I wonder if they added so much whatever that it is using up all of the chlorine. Could they have added all of the metals in the water too?
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    I think that by adding the extra bleach, you will most likely just be wasting it as the sun will eat most of it up.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    That's why, especially in the beginning, you should check FC every hour or so. At 8 hours, you will like
    Y fall below target, even if you you overdose.
    Jul 2014
    St. Louis
    15
    Well, we've been adding chlorine to our pool for 2 weeks now. I work, so it is usually once in the morning and once or twice in the evening. So far we have added 23 jugs of 8.25% Clorox.
    Over the nights, the FC will go from 13 to ~10.5 the next morning.
    During the day it will go from 13 (after adding chlorine in the morning) to ~6-7 by 6pm.
    Our CYA has held steady at ~34. On the plus side, you can see the bottom of the pool now, and with vacumming it looks better and better.
    I was wondering how typical it is to use >20 just of chlorine while SLAMMING. Also, is the FC loss test meant to measure from ie 13-12ppm overnight, or 3-2ppm?
    This summer has definitely been a learning experience. I've almost given up on swimming this summer, but would like to get everything down so that I can hit the ground running next year.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If you can see the bottom it's safe to go swimming in the higher chlorine water up to your CYA/SLAM level. You could dive in for a dip if you wanted to.
    If I only used 20 jugs I'd be a VERY happy camper but I do have a lot more water to treat. I usually start out with four cases of 4X1gal jugs of 12% to start out with and then a few more trips as the SLAM continues.
    Photos of owners being creative in keeping track of how much bleach they've used.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2014
    St. Louis
    15
    Thanks, but can I perform the FC loss test after adjusting the chlorine to 13 at night? Or is it best to test at lower levels?
    Jul 2014
    St. Louis
    15
    Here is a pic of our pool this evening.
    FC 5
    CC <0.5
    I'm going to see what is the drop is by tomorrow morning. Hope it goes well!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The OCLT is usually done at the SLAM level. I do not know if doing it at a lower level would work as an indicator.
