Thread: Vinyl liner leak
    Jul 2014
    Charlotte nc
    1
    Vinyl liner leak
    Hi All- been reading TFP for awhile and thanks for the help. I bought a house about a month ago and had trouble getting the pool balanced. Thanks to this forum everything is good to go. Crystal clear.
    This is my first post. I found a leak in the bottom of the liner near the stairs. It was pretty easy to fix with a repair kit for $5. It seemed to work for awhile but the leak is back.
    If I'm going to patch up the leak again should I remove the old patch or just put a bigger patch over the old one? I'm afraid if I remove the first one it may rip, causing the hole to get bigger. Anyone ever had a similar problem?
    Re: Vinyl liner leak
    Hi Willy.. Had a LARGE pull/tear in my liner under a skimmer. Used a patch from same type material and use BullFrog adhesive to bond. Been over a year now and has held great. I understand that covering the existing patch is preferred rather that risk pulling the old patch and making it worse like you mentioned. I'm sure others will speak up and give some good advice. Good Luck !!!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Always cut a larger patch and go over the old one. I cut the patches into circles so that it holds longer. Never cut square patches.
    Good Luck.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Know anyone getting rid of their holey Intex pool? Grab it up and cut it for patch material. Reinforced patches!
    Hmmm maybe I should do that, and put together patch kits!
    Good idea.....do it !!!!
