Results 1 to 8 of 8
Thread: do i need a new set of cartridge filters?
    delirium330's Avatar
    Dec 2013
    Sacramento, CA
    104
    I'm pretty sure these are the original filters from when the pool was built in 2003. They seem to be working fine, I've had crystal clear water all summer sticking to TFP methodology. The pictures were after I cleaned them. Filter pressure at 2.5PSI after cleaning and usually takes a couple of months to reach 5PSI which is when I usually will clean it. A new set is about $400.
    Built 2003, 14k Gallons, IG Pebbletec, Primary Pump: Sta-Rite Intellipro VS, Sta-Rite Series 3 S8M150 Cartridge Filter, Fiberstars Jazz Light w/Color Wheel, Polaris 280 Vacuum (Runs Zodiac PB4-60 Booster Pump) and 2 Waterfalls (Run on separate, dedicated 1HP Sta-Rite Max-E-Glas II Pump).
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: do i need a new set of cartridge filters?
    Have you ever soaked them in TSP (trisodium phosphate)?
    Since TSP seems to be getting harder to find, dishwasher detergent powder is a good substitute.
    1 cup per 5 gallons of soak water, and about 1/8 cup bleach per 10 gallons.
    Other than being stained a bit, you wrote that they seem to still be working, so soak overnight, and see what they look like after.
    happyheathen's Avatar
    Sacramento CA
    225
    I notice those seem to use paper bands. The ultra-cheap carts which just rolled in (4/$126 - Amazon) at least use nylon strapping.
    I have some vinyl tape (sold as masking tape). It is thinner that "electrical" tape, and not as sticky - once it sticks to itself, it stays. In my attempts to patch together carts, I've found it works well.
    The brand is Permacel - which may have changed over the 18 years since I bought the stuff.
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Dec 2013
    Sacramento, CA
    104
    Quote Originally Posted by happyheathen View Post
    Thanks for the suggestion, do you have a link to those cartridge filters on Amazon? Are they a legitimate replacement for the Sta-Rite versions?
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Quote Originally Posted by delirium330 View Post
    I also have a Sta-Rite System 3 cartridge filter, and I have looked around a bit for aftermarket replacement cartridges. I don't think there are any, you have to bite the bullet and get the OEM cartridges ($$$). If you google "Sta-Rite System 3 retrofit", you will see that someone makes a retrofit gizmo that fits in the tank, then you can use their cartridges. I have no experience with the product.
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    Sacramento CA
    225
    These were made by something called "American" (made in USA! - as if that excuses cheap construction).
    I would NOT recommend these (they were advertised by the Hayward part number - just slightly deceptive...
    Pleatco is about as cheap as I'd want to go.
    Just for my own curiosity, I looked up the carts for that beast - I could not beat $400/set.
    One thing you might try - get VERY accurate dimensions for each and go to a place which just asks for dimensions - be sure that sq footage is one of the dimensions.
    Maybe somebody else uses a cart with the same dimensions, but does not sell them as replacements for that filter. If you can find the tall one for $100 and the fat one for $150, it might be worth the time spent searching.
    Pool Supply World offers search by part or by dimension ( http://www.poolsupplyworld.com/repla...?cmpid=nav_top) - I also ran into someplace which had a name sounding like all they did was carts - didn't bookmark, and don't remember. Sorry
    Dave
    Sacramento
    Jul 2011
    Perrysburg, OH
    88
    As my dad always said "If it ain't broke, don't fix it"
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Dec 2013
    Sacramento, CA
    104
    Thanks for all of the input. Since this is my first go at pool ownership I just wasn't sure how long these things really should last. They seem to be doing the job so I suppose I'll leave them alone for the time being.
