Thread: What kind of motor does the "newer" variable speed perm magnet pumps use
    Mar 2012
    Maryland
    87
    See how expensive they are. It seems to me much of the expense is in the fact that they have a digital computer circuit and a perm mag motor. Is the motor simply a DC "type" treatmill motor. Because if this is the case you can get them pretty cheap and then use a Full Wave Rectifier to the motor.
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What kind of motor does the "newer" variable speed perm magnet pumps use
    The motors are designed specifically to work with a VFD to minimize arcing. They have a PM rotor and a winding stator but effectively they are AC driven albeit PWM AC. So no the motor is not a common treadmill motor nor is the drive a simple full wave rectifier. The drive is a VFD which converts the AC to DC but then converts the DC to a PWM waveform. You can read more about it here:
    http://www.pumped101.com/index.html#..._speed_pumping
    Mark
    Aug 2010
    Dallas, TX
    4,052
    I would love a 3 phase pump. Problem is, I am probably in the very small minority of homes that have 3 phase.
    Mar 2012
    Maryland
    87
    How about a 240 pump v.s. a 115?
    38,295
    All but the smallest 2 speed and all the VS pumps are 230 volt.
