Thread: FC target for SWG. Should the guide be revised?
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Picking up a thread from the Getting Started forum, with a specific topic that's better to discuss in Chemistry 201.
    Water Balance for SWGs:
    http://www.troublefreepool.com/conte...rine-generator
    To summarize:
    FC 3-5 ppm
    CYA 70-80
    I do see that the CYA chart on this site suggests higher for SWG.
    CYA 70 Target FC 5
    CYA 80 Target FC 6
    FC of 3-5 may be fine for minimum, but is that really high enough for a TFP?
    Should FC 3-5 on the salt water balance page be revised/raised? If no, why? If yes, why, and to what?
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Aug 2010
    Dallas, TX
    4,052
    Re: FC target for SWG. Should the guide be revised?
    I really use the pool calculator for FC as a MINIMUM. I have my target as 5-6 so that I never fall below 3.
    FC of 4-6 is consistent with the chart. Article updated.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    The summary at the bottom of the page needs the update as well.
    Good catch. Thanks.
    Fixed.
