Thread: TF-100 testing on 5th day
    Jul 2008
    Dallas, NC
    TF-100 testing on 5th day are my test results....I think I have tested what I was supposed to! BTW water is very clear.
    PH 7.3
    FC 1.0
    CC 1.0
    TC 2.0
    TA 100
    CYA -- Less than 20, I could still see the black dot at the bottom of the tube.
    Water temp 82F
    I am having a bit of a problem because I forgot to think about the fact when I ordered the test kit that I am colorblind to some shades of red and green. I think maybe that is hindering my test results. I also used the "daily" small kit that is in the large kit, and my CL does not even change the water color at all, so I think I am pretty close with the above results.
    I know I need to add and up the CL.....pool calc says 63 oz of bleach. I got that far before my head started spinning around on my neck. I know I also need to add more stabilizer to get it up between 30-50. Pool calc says 25oz of stabilizer. Now since my PH is low.....I need to aerate or add 17 oz of borax. If I understand correctly, when I add the stabilizer it will lower my PH.
    Am I close on any of this? Will someone check behind me please?
    7600g AG Intex Frameset 18'x48" Just installed in July '08.
    Hayward Sand Filter (14inch Sand Filter/40gpm pump) Install May 10th '09
    TF100 Test Kit
    BBB Beginner!
    Butterfly's Avatar
    South Carolina
    Re: T-100 testing on 5th day
    Hi Lori,
    Because you have CC of 1 and your FC has fallen below your minimun FC of 2, I suggest you shock your pool.
    Pool School has an article for shocking your pool.
    I would leave the pH alone for now and just keep a check on it.
    You are on the right track with your CYA with a goal of 30 to 50.
    Later, you can think about lowering your TA if you have problems with rising pH.
    You're done SLAMing when:
