Thread: Is this worth it.
    Mar 2012
    Maryland
    87
    Is this worth it.
    It looks like a flo-matrix. At least there are some good parts. I'm assuming the winding is somewhat bad if it keeps tripping the breaker. Maybe I can just remove the ground (he he he).
    http://smd.craigslist.org/spo/4586194661.html
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    Casey's Avatar
    SW PA
    10,444
    Re: Is this worth it.
    I would leave it exactly where it's at, on Craig's List.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,479
    Not worth the risk. Keep looking.
    Kim
    mas985's Avatar
    Pleasanton, CA
    11,737
    How does he know it works if it keeps tripping the breaker? That means it doesn't work although it could just need a new capacitor or cleaning of the centrifugal switch.
    You could let him "show" you how it works and when it trips the breaker, tell him that it doesn't work but you will take it for $20. The wet end is worth at least that.
    Mark
    Mar 2012
    Maryland
    87
    Well looks like it was a great deal. I went to the guy's house. I talked him down to $25.00. I took it home and took the motor apart. It appeared that the bottom of the motor had sat in water (low) for some time as it had some surface rust. It appeared the starter winding switch had worn through. In addition the motor thru bolts were rusted and one was broken. I ordered the switch on ebay and made some thru bolts out of 8-32 threaded rod and nuts. I plugged it in and it powered up. I ran it for a few minutes, heat and everything else was good. My assumption was the starter switch was bad and that cause the motor to overheat.
    Jul 2012
    Tallahassee, FL
    30,479
    That worked out for sure! Good job!
    Kim
