The heat is not good for liquid chlorine. Others normal chemicals should not be affected. A note that you should not be storing the bleach and muriatic acid together if you are.
The seal on my "new" bottles is often eaten away. It makes opening them a pain. I started keeping them where they get fresh air after rusting some stuff.
While it is dangerous to store MA and chlorine together, you don't want to anyway. Since a cool dark place is unlikely to be well ventilated (in the summer).
