Results 1 to 12 of 12
Thread: Fire Pit Burner Ring Recommendations?
    Jun 2014
    Lake Jackson, Texas
    133
    Pool is under construction and am going with a fire pit as well. Which ring or burner do you recommend? Crossfire system? Regular ring type, etc…?
    Also, lava rock or fire glass?
    Does anyone have a fire pit hooked up to there pool controller?
    Thanks!
    Casey's Avatar
    SW PA
    10,423
    Re: Fire Pit Burner Ring Recommendations?
    Welcome to TFP.
    Not sure on what fire ring to recommend but I would assume that it will come down to personal preference on lava rock and/or fire glass.
    Good luck with it and post pics!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Previous house, no pool. Whe we were expanding our hard scape including lots of pavers we wanted a fire pit included. The contractor could have kept his mouth shut and sold us one, but he let us know that most of his clients later regretted a built in fire pit. Too much patio "real estate" lost to too little use. He suggested we spend a few hundred dollars at Lowes for a portable pit rather than several thousand with him. That was three houses ago and we still prefer the portable pit. We can have a fire when we want, but get it outa of the way when we don't.
    Make sure you understand how you will use it and that it fits long term.
    Support the site
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Tim, Great advice!! I have had both. definitely prefer the movable one. My movable one was always a wood burner. 80% of my friends always preferred the wood burner. I cant describe the oneness with nature you feel when you are the one who has to move because the wind shifted.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    I take it that the 20% that didn't like it were the ones down wind. Lol.
    19,000 gal aqua blue pebble sheen, 3.5-7 ft. depth, chiseled flagstone coping, spillover spa, raised back wall with stacked stone face including two columns and curved wall water feature with three 18" sheer descents, two bubblers on 5' x 10' suntanning shelf, Pentair IntelliFlo Variable Speed, Pentair FNS Plus 60 sq ft DE filter, Pentair Mastertemp 400K BTU, Pentair Legend, Rainbow 320 chlorinator (now unused), K-2006 test kit.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I have had both but the house we have now has a gas fire pit. It has three straight gas burners and we have a fake log kit like in our house gas fire places. We just have fancy rock over the burners and the logs sit on top. I like the real fire pits but in our case we back up to a wooded area that gets dry sometimes in the summer and the ashes from a real pit may causes issues. The gas one we have you shut off and go to bed.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Good Point wjr. All my homes have had a safe place to have an open fire. I even lived for years in the mountains just above Denver. Small detail is to always have a water hose at the ready. In all these years I only needed it once.
    The ones who didn't prefer wood fires were definitely not designated drivers and they couldnt get out of a chair.....LOL
    Jun 2014
    Lake Jackson, Texas
    133
    Thanks for the comments! I have the fire pit on one side of the pool area and a drain has been plumbed and I threw in conduit and power before the decks went in along with the LP line. 1100 square feet of deck got poured on Saturday so we are definitely getting one now. Lol… It probably won't be used much but I would like to have it there.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I was at a party this weekend and they had a real fire pit right next to the pool. He said He doesn't use it that much because he gets a lot of floating ash in his pool. Never thought about that.
    Jun 2014
    Lake Jackson, Texas
    133
    Yea, that would kinda suck. I could see that with wood but this one is propane and will either have lava rocks or glass so I suspect there should be no ash from that...
    wjr75's Avatar
    Jun 2013
    IL
    836
    Gas fire pit no problem! That's what I have and when your done just shut off the valve and go to bed
    Jun 2014
    Lake Jackson, Texas
    133
    Yup. That's what is being built now however I can't decide if I want to go with an electronic ignition that hooks to the pool controller. I personally ran a circuit to the pit area just in case I do as well as conduit back to the controller area for a control wire but my builder does not like the auto light system but admits he is old school when it comes to the automation stuff and he does not like it. Besides the cool factor of lighting a fire from your phone, I like it because you set your gas valve and forget it and it has safety features. The control box on the ignition system fires up the pit and if for any reason it goes out, it re-lights it. The gas is only flowing if it is lit. If the gas goes out on a manually lit pit I guess you are just pumping the fuel (obviously you should be watching for this of course). Me personally, I love automation and insisted that I have that capability vs. the controller the builder was going to install. I may hardly ever use it but just knowing it is there will make it allllll right. Lol
    I was also looking at the Crossfire system that Warming-Trends offers. They claim to use 50% less propane/gas than other systems. I was hoping someone had one of those and could comment on it...
