Results 1 to 10 of 10
Thread: Manual for a Jacuzzi 250 sand filter
    Jul 2008
    Ottawa, Canada
    11
    I'm looking for the manual of a Jacuzzi Laser 250 sand filter. Secondly, can anyone describe the OEM relationships of pool filters? I just bought a house and I have no manual for my pump or my sand filter. My filter is branded Club Pro Laser 250, but I believe that its just rebranded from a Jacuzzi Laser 250. However, in searching the internet I can't find a manual for the Jacuzzi 250 or even find it on the Jacuzzi home site. I'm in Canada, so it may change the branding of the parts.
    Pool Size = 27,000 gallons
    Inground SWG, Vinyl, 1.5HP, Sand Filter (250lb), Nature2 Purifier
    Dec 2007
    Central New York
    504
    Re: Manual for a Jacuzzi 250 sand filter
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    The link posted with the manual is very helpful, I wish I would have found something like that. I already new pretty much everything it said though. The only thing I wonder about(and have seen in other places) is, why do you put some water in the tank before adding sand? The other thing is, people refer to sand filters in inches, such as a 16" filter, what does this mean?
    If you have any questions about your filter, feel free to ask, I've had one very similar(Jacuzzi Splash-Pak) and have learned just about everything about it one would need to know to do simple fixes and operation.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    The two main reasons to put water in first are, 1 so you don't damage the laterals 2 so you don't get a heap of dust in your face. Also make sure you backwash and sinse a couple of times before the first use.
    Happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Jul 2008
    Ottawa, Canada
    11
    This is exactly what I was looking for. Thank you. I'm still trying to figure out the flow of water through the filter. I realize that it is different for each setting, but these are the 3 I'm looking at.
    Filter = Water gets pumped into the top of the filter and pushed out the bottom and back out to the pool
    Backwash = Water gets pumped into the bottom of the filter and pushed out the top and out the drain
    Rinse = Water gets pumped into the top of the filter and pushed out the bottom and out the drain
    Is this right?
    One post said that the you alternated between backwash and rinse, while the manual says to run rinse for 30 seconds then stop saying it was used to repack the sand. Are the perhaps both right?
    Apr 2008
    Thailand
    152
    yes and yes I'm pretty sure rinse goes in the top and swirls around and goes out the top and drains. i'm sure someone will correct me if i'm wrong.
    Cheers Frank
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    You are correct as far as the functions go. Rinse does two things, first, it flushes out any remaining dirt so it doesn't go into the pool, and second it repacks the sand. I've never heard of anyone saying it repacks the sand, but it makes sense, since water folwing from the bottom would tend to loosen and stir it all up.
    HTH,
    Adam
    Jul 2008
    Ottawa, Canada
    11
    Great, now can anyone tell me what 'Whirlpool' setting does? Surprisingly the manual says nothing about it. Should this only be used if the filter is for a hot tub or does it perhaps aerate the water as it filters (that would be nice for raising PH)
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    The Whirlpool feature just bypasses the sand. This allows maximum water flow but doesn't filter the water, just circulate it. I find it works well to get all of the **** that settles to the bottom in the middle so vacuuming is faster because I don't have to do the whole pool if I just want to get the big stuff.
    HTH,
    Adam
    Better late than never
    Try
    http://www.competition-pool.com/
    Gordo
    YAGER
