Results 1 to 8 of 8
Thread: Sodium Hypo and ph
    Jul 2013
    western new york
    62
    Sodium Hypo and ph
    I was wondering how directly chlorine usage is responsible for the ph rise in pool water. I am wondering if there is a way to quantify it, if it is. My thinking is... Would it be possible to add HCl (very dilute HCl I imagine) to my chlorine holding tank on my stenner chlorine feed system.
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Sodium Hypo and ph
    Insignificant. pH rise is usually due to aeration from SWGs, fountains, bubblers, etc.
    Donldson's Avatar
    NW Ohio
    2,896
    Not if you enjoy living. Acid plus chlorine make chlorine gas, diluted or not. Chlorine does raise the pH when added, but then it comes back down as the chlorine is consumed. If you are having problems with your pH constantly rising your TA is more likely the cause.
    So please don't add acid to your chlorine tank.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2013
    western new york
    62
    Quote Originally Posted by Donldson View Post
    I do notice that my ph tends to rise gradually .. I am currently adding (via stenner) 38 fl oz/day of 12.5% hypo and its been working well. About one a week, I need to add 6-8 fl oz of 37% HCl. I usually add when ph is 7.8 and shoot to bring it down to 7.4 My HCl usage has been very consistent.
    Aug 2010
    Dallas, TX
    4,052
    What is your TA?
    38,299
    It is pretty normal for the pH to tend to rise ... unless you are using acid solid chlorine products.
    Jul 2013
    western new york
    62
    Quote Originally Posted by RobbieH View Post
    What is your TA?
    110 (last i tested about 5 days ago)
    Lowering your TA will eliminate, or at least greatly reduce, the PH drift.
