Results 1 to 7 of 7
Thread: How often add chlorine?
    Jul 2014
    albuquerque
    15
    Split by moderator. Please do not hijack another member's thread. Always ask you own questions in you own thread. Thanks, jblizzle
    How often should chlorine be put in the pool? Is this an every day thing? I'm asking because I've been having to add a little bit every day. it has been extremely hot lately so that may have something to do with it.
    20 X 40.....32000 Gallons.....Gunite.....Live in Albuquerque New Mexico...............Sand Star Pump...Heater but only use when we first start up in April/May...
    38,540
    Re: How often add chlorine?
    A basic tenet of TFPC is testing and adding chlorine as needed ... this is usually daily. It is normal to lose 2-4ppm of FC every day.
    Jun 2014
    Douglasville, GA
    53
    Yes, chlorine should be tested and adjusted (if needed) daily to stay in range according to the CYA/FC chart. Never let FC drop below the minimum level.
    Once the pool stabilizes, you may find that you can set FC a little towards the high side and skip a day (I do this), but never more than one day. It isn't worth it to let the pool slide and have to SLAM again. I think a popular saying around here is "treat it like a pet: you don't have to play with it every day, but you do have to feed it".
    33K gal vinyl IG, 1.5 HP SuperFlo pump, Hayward S244T sand filter (62GPM)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Almost. Check my signature.
    Jul 2014
    albuquerque
    15
    Thank you all....and I apologize for placing my question in the wrong place
    Jul 2014
    albuquerque
    15
    Thank you TFP.....I get to enjoy my pool and save about 500$ a month when the pool store tries to get me to buy their chemicals...got a big pool...wouldn't go back to floaters and shock and phos free for anythingimage.jpg
    T
    Casey's Avatar
    SW PA
    10,461
    It is highly recommended that you have water in your pool!
