Thread: Which Spider Gasket for this Pentair MPV Valve?
    Oct 2012
    Houston, TX
    29
    I Have this MPV, and I believe it is leaking(actually i'm sure of it)
    I did a bit of research online, and the valve looks most similar to 261152, but it doesn't say which spider gasket goes with it???
    40,000 gallon ig gunite, Pentair Challanger Century Centurion 2.2 HP Pump, FNS 60 DE filter, Polaris 280, Century Centurion 3/4 HP Booster Pump, Attached ig spa - 1HP Centurion pump - Dual non functioning blowers
    Casey's Avatar
    SW PA
    10,438
    Re: Which Spider Gasket for this Pentair MPV Valve?
    To help get answers...
    I think that you are correct. The valve is an SM 20-2, which is product number 261152 and goes to an FNS DE filter. It takes 2" plumbing, and the part number for the gasket is 271148.
    "261152 2 in. MPV, for FNS, FNS Plus & NSP filters [SM 20-2], 7.5 in. Centerline.
    271148 Spider gasket diverter, 2 in."
    Support the site
    Oct 2012
    Houston, TX
    29
    Thank you. I like to check here before I check the store... thanks!
