Thread: Baquacil Conversion
    Jul 2014
    Sussex
    1
    Baquacil Conversion
    New to the site, I am converting to chlorine from baquacil. Looking for a little help. Started doing the conversion under information the pool place was giving me. They tested my water and gave me a product called quick clear (which is a non chlorine shock) to remove the baquacil from the water. After having tested the water many times and dumping pounds and pounds of the quick clear the baquacil sanitizer and alagstat readings from them are at 0 but the oxidizer is still at around 60. they are telling me I need to continue adding the quick clear, they also gave me a product called flip out to use until that reaches 0. From what Ive read searching this seems like its untrue. I do not want to keep adding random chemicals to the pool trying to chase a 0 oxidizer number if I don't have to. My pool has gone from a brownish color, to a greenish color to a cloudy blue, and today it seems crystal clear. so my question is, do I need the oxidizer reading to read 0? Should I start adding chlorine slowly or should I shock it every day like the pool place is telling me to do when the oxidizer reaches 0?
    After searching on this site I know I need to pick up a good test kit. Which I will do asap.
    Thanks for any help,
    Dave
    Casey's Avatar
    SW PA
    10,453
    Re: Baquacil Conversion
    Welcome to TFP Dave! Get the TF100XL ASAP! You can order through the link in my signature.
    Also, read this:
    Convert Your Baqua Pool To Chlorine
    Chlorine is both just as effective at doing a conversion, and it costs less.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    I used chlorine and the directions from this website 5 years ago to convert from Baquacil and I've never been happier with the pool
    Good luck with your conversion
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Quick Clear = quick profit for!the pool store. Chlorine, bleach or 10/12.5% chlorinating liquid is your answer.
    Support the site
