Results 1 to 8 of 8
Thread: Pulling up concrete deck
    May 2011
    Orillia, ontario, canada
    50
    Hey,
    I'm about to under take a big pool reno. Just curious if there is anything to worry about when removing a concrete deck around an inground pool.
    Do i have to drain the pool to do this? Will the sides collapse? How long can i leave the pool without concrete around it?
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    Jun 2011
    Carlsbad, NM
    172
    Re: Pulling up concrete deck
    I just went through this on our renno. I bought a 70lb jack hammer and a 12" concrete saw. Nine days later, we had it all out. My advise is to be careful when cutting near the bond beam. We did it with the water in the pool and had to scoop some concrete and pebbles out of the pool, but it was no big deal. After taking all that care, we realized that the pool was in worse shape than we thought. We are now in the middle of extensive repairs, new skimmer, light, waterline tile and plaster. (all DIY but the chip out and plaster.)
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Apr 2013
    Sacramento, CA
    2,769
    Don't you already have a related thread on your pool?
    The tough part about this is getting rid of the concrete. It often makes more sense just to pay to have it removed just because they have to get rid of the waste.
    You want to make sure you don't damage the electrical, suction and return lines. They are never where they are supposed to be. You also want to protect the top of the walls and the pool floor.
    You don't have to drain the pool, the sides should be held up by supports burried in concrete at the base of the walls. If your pool was built correctly and the walls are not rusted out then you should be able to leve it without decking for a while. That said, generally you want deck to surround a vinal liner pool so the soil next to the pol does not expand and deform the walls.
    Finally, when you replace the deck you want to be sure the pool and deck are properly bonded.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Smracing
    "Don't you already have a related thread on your pool?"
    Yup, basically just a continuation of: http://www.troublefreepool.com/threa...crete-amp-trim
    Solar Blanket, Well Water, Borax Added. 68
    May 2011
    50
    I managed to get one corner out. I found concrete sonotubes that we're attached to the concrete deck. When I was smashing the concrete deck I saw the concrete pillar move up and down.
    The back fill is sand and not gravel. I have 1 piece of 1/4" rebar on the outer edge of the concrete.
    I still don't understand why the deck is sinking.
    I will be getting a contractor to remove the rest of the concrete. Should I remove the sand and see if they put a concrete neck/skirt to hold the steal walls in place? I read the I should replace sand with 3/4 gravel.
    Apr 2013
    Sacramento, CA
    2,769
    In another thread you talk about swampy soil. Any type of soil full of water is going to cause problems to a deck even with a couple of feet of sand or rock. You need to get rid of the water.
    You might have a couple of local concrete contractors over to look at it come up with some solutions and some bids. That way you will get a local onsite opinion on what is happening.
    May 2011
    50
    Quote Originally Posted by gwegan View Post
    What do you mean bonded?
    I'm also not sure where my bond beam is.
    Are you guys talking about the where the concrete attaches to the coping.?
    I think I'll be replacing the coping all around depending on price. It will probably be something for interlocking stone.
    Everybody I talk to in my city says it was a swamp before. How can I verify it was? Dig a hole beside the pool and see if I hit water?
    wjr75's Avatar
    Jun 2013
    IL
    836
    It doesn't look bad to me from the picture? power wash and reseal? I'm getting quotes to do that for stamped concrete. My deck also floats from the main pool. Meaning it's not connected.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
