Page 1 of 4 1234 LastLast
Results 1 to 20 of 71
Thread: Water Balance Question
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Hi,
    I'm new to the forum, but have already read quite a bit. I have a question regarding the "Water Balancefor SWG's" article.
    It gives a summary of water goals as such:
    FC 3-5 ppm
    PH 7.5-7.8
    TA 60-80
    CH 250-350
    CYA 70-80
    Salt 200-400 ppm Above recommended optimum level
    My question is, does this change any for me since my pool is indoor?
    To give a little more info than my signature, I have eight good sized skylight windows in the roof. I don't now if that matters, but I thought I'd share it.
    Thank you and thanks for such a great website.
    14K gallons...Inground, Indoor, Plaster...SWGPool Pilot Digital Nano
    Hayward 1.5HP pump/Hayward Star Clear Plus - Cartridge
    Sta-Rite Max-E-Therm Heater 400K BTU LP
    Hot tub (600 gallons) flowing into pool
    Jun 2014
    Douglasville, GA
    53
    Re: Water Balance Question
    Interesting...one thing that jumps out is the CYA. It usually isn't needed for an indoor pool, but with the large skylights you might need a little. It depends on whether or not the material in the skylight blocks UV rays or not. Does the SWG manufacturer give any recommended settings specifically for indoor pools?
    33K gal vinyl IG, 1.5 HP SuperFlo pump, Hayward S244T sand filter (62GPM)
    Welcome to TFP!
    For an indoor pool we recommend that CYA be around 20 to 30 (SWG or not). Otherwise all of the recommended levels remain the same.
    The glass in skylights usually block UV, so it really isn't the same as being outdoors.
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Thank you very much. This is very helpful as we were instructed from the pool store to raise our CYA and this is what we are testing currently...
    FC ... 2.3
    PH ... 7.5
    TA ... 81
    CH ... 70
    CYA ... 30
    Salt ... 2500
    I'm having a visibility issue currently. You can see the drain, but it is milky, hazy. I will, however, start a different thread with regards to the clarity issue as instructed by the forum guidelines.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    The numbers look suspicious to me. What are you testing with, or are they pool store test results?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    They are pool store results. I just ordered the TF-100 today.
    Jul 2011
    844
    Great decision.
    Bestway SWG
    38,540
    Please, keep your questions here ... there is not reason to split up your story.
    With hazy water, you likely need to follow the ShockLevelAndMAINTAIN Process once your test kit shows up.
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Okay, I will keep my story here.
    As soon as my test kit gets here I will post my water results.
    Hopefully, one of you experts can help me through the process as I am new to all of this but I am very excited about starting this great process.
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Just as a precursor to me getting my new TF-100 and posting my test results, here is a picture of my clarity issue. Notice that you can see the drain but it is a milky clear.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    You need to get the CH up in that plaster pool.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    I agree. Of course, I did not know that truth until I found this site.
    However, my trip to the pool store last week (before I joined the site) had me add 4lbs of Calcium Chloride to raise the CH.
    They also had me raise my CYA
    So, now knowing that my CYA was at maximum I'm going to have to SLAM at a higher level of FC
    I'm really looking forward to having a TFP.
    Should I wait until after I SLAM to correct CH or should I get the CH correct before I SLAM?
    Last edited by jwp; 07-31-2014 at 05:55 AM. Reason: mistakenly typed sodium chloride
    Wait until after the SLAM to adjust CH.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,212
    Quote Originally Posted by jwp View Post
    It is actually very simple when you think about it, the pool store exists to sell you things. Every time you go in they are attempting to do that. If you don't have a problem, they will make one up. I know all of them are not bad, but between the dishonest ones and the ones that employ untrained staff to give advice you are more apt to walk into a bad one than a good one.
    The folks here at TFP are here helping for free because they want folks to have a great pool experience. If one of use has a bad moment and gives incorrect advice we (I know I have), it will quickly be corrected by another member.
    Let me say welcome to TFP
    Support the site
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    This is sort of a preliminary question, but when I start the SLAM process should I turn off my SWG or keep it on?
    Smykowski's Avatar
    Sep 2011
    3,065
    Keep it off. It will prolong the life of the cell, and at the end stage of the process, it won't interfere with the OCLT (in case you were to forget to turn it off later).
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Okay. Thank you, Smykowski.
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    We just started the SLAM process.
    We tested the water and here are results with regards to the SLAM:
    FC = 5
    CYA = 50
    PH = 7.5
    So, we added 263oz. of 10.5% bleach to take the FC to 19.8 and will retest FC in a couple of hours.
    I will continue to post results.
    Questions:
    1) Do we need to test CYA as frequently as FC? I hope not as the solution will go fast.
    2) How do I shut my SWG off as that was recommended above for the SLAM process?
    Thanks.
    38,540
    Did you test and adjust the pH before raising the FC level?
    You should not need to test the CYA any more for awhile.
    You should test just the FC and CC while you are SLAMing.
    I would assume you should be able to turn the output of the SWG down to 0. You can leave it on if you like, but you have to remember to turn it off for the OCLT and you get a better feel for the progress with it off.
  20. Back To Top    #20
    jwp's Avatar
    Jul 2014
    Ormond Beach, FL
    62
    Hi Jason,
    Thanks for the quick reply. Our PH is 7.5 (I added to my above post for clarification). I will move my SWG to zero.
    So, I can test my FC and CC and be okay through the SLAM process?
    Thanks.
