Thread: Georgia Newbie
    Georgia Newbie
    I am thankful to come upon this site. Water is clear finally.
    45"x24' AGP
    Dream line High rate sand filter 45gpm
    Hayward pump 1.5 h.p. 70GPM
    Ordered new testing unit this week.
    Last visit to pool store 2 days ago
    Temp 89
    TDS:700
    CYA:100
    PH 7.8
    Adj Total Alk 145
    Tot hardness 152
    Saturation Index 0.4
    18,500 gal pool
    I had already paid pool store around $300 only in the last 2 weeks have had clear water,never again.
    AGP 48"x28'
    Hayward 1.5hp 70 GPM
    Dreamline high rate sand filter 45gpm
    Re: Georgia Newbie
    FC_0
    Tot Cl-0
    AGP 48"x28'
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Georgia Newbie
    Well hey there, Welcome!
    If your CYA is 100, and your FC is 0, you will not have clear water much longer. I suggest you get some bleach in there ASAP, dose according to the CYA chart in my signature, and maintain the minimum, at all times.
    If you are confident that your CYA is really 100, I would consider a partial drain and refill with fresh water to get it down to a more manageable number.
    We can help you keep your water clear, be sure to read all the articles in pool school to start.
    BTW, you can update your signature line to include your pool specs and equipment, that is very helpful for those of us responding to questions. Go to your User Control Panel (top left) and then Profile, and then Edit signature.
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Re: Georgia Newbie
    Hi tucker!
    Welcome to TFP my fellow Georgian!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Georgia Newbie
    Hi TuckerPool,
    Welcome to the forum
    You're done SLAMing when:
