Results 1 to 9 of 9
Thread: Heater Question
    Jul 2014
    Hudson Ohio
    142
    Heater Question
    I have a 24' round AGP. I estimate that a 100k btu gas heater will work fine actually down to a 65k. I live in North Eastern Ohio and look to extend the pool season a bit. I like my pool on the cooler side 77 - 80 degrees works for me. What should I expect cost wise operationally? I know there are a lot of factors and I think it would be more of an intermittent usage rather than a constant temp. trying to weigh things out a bit for next year.
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Jul 2014
    Hudson Ohio
    142
    Re: Heater Question
    OK maybe I posted this in the wrong forum... Mods please move if needed to the "Everything Else" Forum.
    Jul 2014
    Hudson Ohio
    142
    Re: Heater Question
    No one???
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Heater Question
    I think there are too many variables for anyone to even guess.
    Apr 2013
    Battle Creek, MI
    298
    Re: Heater Question
    I don't have an estimate for you, other than to say I have a 100,000 BTU Hayward NG heater for our 6,700-gallon pool, and my first gas bill with it running was about $40 more than the same bill a year ago. Some of that was due to a heavy work load of bringing it up to about 85 degrees, which is the bare minimum my wife will get in the pool I expect smaller bills due to just maintenance-level use and the addition of a separate solar-heat system.
    As a side note, about two weeks after I installed the heater, I got a visit from a tech at the gas company. Apparently my steep increase in summer gas usage flagged our account to check for a leak! No, I said, just the new pool heater
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jul 2014
    Hudson Ohio
    142
    Re: Heater Question
    Quote Originally Posted by CeeElGee View Post
    Thanks CeeElGee! thats what I am after. I am really just wanting to know if I am looking at $80 a month or $500 a month. $80 I could stomach pretty well... especially with the use of a solar cover as well. I only get a good 6 - hours of direct sun per day and even with a regular summer I think our pool will be more on the cool side. I just want to maintain a good 76 - 78 degrees.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Heater Question
    Quote Originally Posted by mrramsey View Post
    Remember, everyone's cost for gas is different.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2012
    Hudson Ohio
    47
    Re: Heater Question
    Hi mrramsey, We have a heater for the pool. Have not had to use the heater that much(we like 86 degrees for the water temp). We keep the solar cover on all the time till we swim.Pools stays at a consistent temp.Just got a new budget increase for this year for an additional $40 dollars a month. Also have a furnace in the garage. Was a cold winter and Hubby had projects going on in the mancave(garage). Hope this helps.
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    Jul 2014
    Hudson Ohio
    142
    Re: Heater Question
    Quote Originally Posted by mtucker View Post
    Yes thanks. Its good to get input from someone right around the corner. I think we are going to see how the rest of this season goes and how it it next season.
