Results 1 to 10 of 10
Thread: Burning eyes
    Jul 2014
    St. Simons Island, GA
    172
    Burning eyes
    I have a new Intex vinyl above ground pool, 12,600 gallons, SWG with ozone by Intex. Water is clear, beautiful and does NOT smell like chlorine (chloramines?), yet my eyes burn. Very little sunscreen gets into the water. The pump & chlorine/ozone generator run 8 hours in daylight per day. All I have are test strips. A test strip dipped in before the pump came on and the sun rose above the horizon returned the following results:
    Total hardness 250
    TC 1
    FC 3
    pH 6.8 to 7.0 (which is surprising since I lowered pH to 7.4 by adding about 3/4 box of Borax 3 weeks ago, but it is early morning and it has been raining a lot lately.)
    TA 180
    CYA 50 (which is also surprising since I originally poured in about 50% more CYA than was called for)
    I know I need a better test kit. All good things in time.
    Is the low pH what is causing my eyes to burn? How much baking soda do I add?
    MAJOR EDIT: I didn't trust the test strip, so I used 3 different pH tests from my saltwater aquarium and all three said 7.5 - 7.6. Another saltwater aquarium test said the alkalinity was in the 2.0 to 2.3 range measured in Milli-equivalents per liter.
    So if it's not low pH, what's making my eyes burn?
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Burning eyes
    Few things stand out....
    a. You are correct, test strips not too accurate.
    b. Pump should run before you test.
    c. PH is too low, as you guessed.
    d. I believe Borax would raise your PH, muratic acid lowers.
    e. You chlorine level is too low for your CYA level.
    it would be a great idea to order a good test kit and read pool school while you wait for it to get here!
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Burning eyes
    PAGirl is right. I will only add that if your test results are at all accurate, you do not need to add baking soda.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Burning eyes
    If (BIG if) those numbers are right, all you need to do is aerate to bring pH up. No chemicals needed. You have high TA, so it should be a fairly quick thing. Low pH will cause stinging eyes. If you use the search box for "aerator" and look for the paper clip icon, you'll find pictures of various homemade things. Maybe something will inspire you.
    Also a big IF, if those chlorine numbers are correct, you have 2 CC, which is too high, which can also cause burning eyes. The cure is to raise FC to the appropriate level for your CYA, which it isn't at the moment. Strictly following the TFP dogma, I should say you need to SLAM, but I don't trust the test strip results, and you can't SLAM without the right test kit anyway.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Re: Burning eyes
    Quote Originally Posted by PAGirl View Post
    I will add, chlorine level never seems to effect my eyes, bad pH level on the other hand does cause burning to me.
    Get the pH in line and I think your problem will go away. But, you need a good test kit, not strips!
    Support the site
    Jun 2014
    Douglasville, GA
    53
    Re: Burning eyes
    OK, now to the problem at hand: Low pH could potentially cause the burning eyes issue. Pool math says ~6lbs of borax to get it from 7.0 to 7.5 with 12600 gallons. EDIT: With high TA you should aerate to raise pH as stated previously.
    However...you also state TC=1 and FC=3, which means CC (combined chlorine i.e.bad stuff) is at 2. This can cause burning eyes as well.
    uh oh...this might nave been a mistake.
    33K gal vinyl IG, 1.5 HP SuperFlo pump, Hayward S244T sand filter (62GPM)
    Donldson's Avatar
    NW Ohio
    2,880
    Re: Burning eyes
    Correction: if those numbers are correct, he has -2 CC. Since this is impossible, I submit it as evidence that those strips are not worth the paper they were glued to.
    Proper test results are key, the sooner you get them the sooner your problems can be solved. I say this as someone who put it off initially and realize now that it would have saved me a lot of time and money that season.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2014
    172
    Re: Burning eyes
    Thank you for the quick replies.....a little too quick as it turns out, b/c I was editing my original post as ya'll were posting replies. Regarding the aeration, the chlorine/ozone generator includes a fractionator, so the water coming out is seriously aerated (hopefully with ozone)
    Jul 2014
    172
    Re: Burning eyes
    Quote Originally Posted by Vince-1961 View Post
    Total hardness 250
    TC 1
    FC 3
    pH 6.8 to 7.0 (WRONG! SEE BELOW)
    TA 180 (Also wrong.)
    I found a conversion chart and see that 2.0 to 2.3 mql is about 90-110 ppm on the alkalinity scale, so that test casts further doubt on the accuracy of the test strip. Ordered the Taylor K-2006 FAS-DPD test kit. I'll dip another test strip when I get home today.
    Aug 2010
    Dallas, TX
    4,052
    Re: Burning eyes
    As he said above, it's not possible for FC to be 3 and TC to be 1, as the formula is FC+CC=TC.
