Thread: Raise Ph by aerating. How long to aerate.
    May 2014
    Clarksburg, WV
    331
    I did a few quick searches to find out how long to aerate my pool to raise Ph and didn't really see a good answer.
    So I'll give my example so maybe it will help others.
    My Ph has stayed at 7.5 for weeks. I added 2 pucks the other day while taking a trip and my Ph dropped to 7.2. I like to keep it at 7.5 so I aimed my return jet straight up and left it like that from about 5pm till 7am the next morning.
    Ph rose back to 7.5.
    So to raise Ph in my size pool from 7.2 to 7.5 I had to aerate for about 14 hours. And I had the return jet pointed up as far as it would go.
    Hope this helps somebody...
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Raise Ph by aerating. How long to aerate.
    What is your TA level? If we know that, your observation will be very useful so people can have an answer to "How long will it take?" If it's really high, the pH will rise a whole lot faster than that.
    The fourth chart down in this thread shows the rate of CO2 outgassing. Other than seeing that at lower pH and higher TA it speeds up, don't ask me what it all means, it's way above my paygrade!
    May 2014
    Clarksburg, WV
    331
    When I tested and got the 7.2 reading, my TA was at 100 or 110. It stayed at 110 for a long time then I think when my Ph lowered, my TA also lowered down to 100.
    TF-100 Test Kit
    How to SLAM
