Results 1 to 10 of 10
Thread: "Solar Heating Rings" - Worth Taking Home?
    happyheathen's Avatar
    Sacramento CA
    225
    I am crippled with Osteoarthritis, so wrestling with a full size, one-piece cover is not really an option, but I would like some sort of evaporation barrier (the sun in this area is vicious).
    Those rings (if still made) would probably be better than nothing, and, if they do actually heat the water, so much the better.
    Anybody have experience with these? Are they a pain to deploy and retrieve? Do they fall apart after 2 seasons of sun 350 days/yr.?
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Jul 2014
    Fresno, California
    26
    Re: "Solar Heating Rings" - Worth Taking Home?
    Good post very interested as well...
    Intex 15x48 AGP
    Krystal Clear pump 637R
    Krystal Clear SWCG CS8110 EG
    TF-50 on its way
    Sacramento CA
    225
    Now, if only I could get an answer, we'd be set!
    (hint, hint...)
    Dave
    Sacramento
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Try the search box.
    Donldson's Avatar
    NW Ohio
    2,892
    What Richard said, they have been talked about plenty before.
    They are a pain. I have wanted to defend then all season until it occured to me, "wait, you haven't used them all season because they are too much a bother." So I guess I have to admit I am no longer a fan of them.
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Orlando, FL
    690
    Cutting a solar cover into a few manageable sections would be my suggestion.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    The rings don't do much in my opinion. Is a solar cover and a roller an option?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Sacramento CA
    225
    Sorry. Forgot to search.
    the only way I could see using a full-sized cover would be to have (fixed) rollers at each end, with vinyl-coated cable running the length of the pool - one on each side, and one in each direction
    Say cables 1 and 2 are on the north side, and A and B are on the south side.
    If the cover is wrapped up on the S end, cables 1 and 2 would be running the length of the pool, and the N roller would pull 1 and 2, and thus drag the cover.
    To re-roll it on the South end,I crank the southern roller, pulling cables A and B.
    This has the problem of introducing a trip factor at the water's edge. but if I'm supposed to move the roller down the side of the pool as deploring or retracting the cover - well, that isn't going to happen.
    Still haven't figured out how to keep the force equal on all corners, or keep the center from dipping down and picking up few hundred pounds of water.
    Hence the rings.
    I got the impression that many, if not all, get their flotation from air trapped in compartments. Which model(s) can be cut up without losing buoyancy?
    Dave
    Sacramento
    Jul 2011
    844
    I'm not sure I understand what you're describing. Anyway, the regular solar covers are made with bubbles throughout and float. You can cut them any way you desire and they will float, no matter how large or small the piece is - 1 inch square or 1,000 fee square - no buoyancy lost.
    Bestway SWG
    Sacramento CA
    225
    Sorry - my mind was still on the rings, so I did not thinkof cutting a regular cover. Just might work.
    Dave
    Sacramento
