Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Adding ball valve with Hayward skimmer on Intex Ultra?
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hello, got my 16x48 Intex Ultra up a few weeks ago along with the Hayward skimmer. I need a ball valve as I'm still running the Intex flex hose and cartridge filter. So now if I want to clean the filter I have to lift above water level or let it leak. What a hassle, please help! =)
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Re: Adding ball valve with Hayward skimmer on Intex Ultra?
    Would these work to attach the Hayward Skimmer to my Intex flex hose with a ball valve inbetween for my Intex 16' with 635T? Which ball valve and size do I need?
    I cant clean my filter without making a mess and losing water LOL!
    http://www.doheny.com/poolsupplies/I...-Fittings.html
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Apr 2013
    Battle Creek, MI
    298
    I use something almost identical to this: http://www.ebay.com/itm/SWIMMING-POO...item3a92e040a9 It came with my Hayward D.E. filter. I also use a few ball valves that cost $10 at Lowe's, but they are 1-1/2" PVC slip connections. You'd then need a threaded adapter for the skimmer and the hose barb.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jun 2014
    206
    Right now I just have the hose pushed on and clamped to the bottom of the Hayward skimmer lol
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Orlando, FL
    690
    I have a ball valve right at the pump that I close when cleaning the basket on my pump. When I need to disconnect the suction and return lines to the pool, I close this valve, close the filter, and stick a sock on the return port. The valve on the inlet to the pump looks like this http://www.warmwatersolutions.com/Ac...ball-valve.jpg (I cannot open the link you provided.)
    Easiest solution, stick a sock in the skimmer and the return, you will be able to clean your filter without draining the pool or getting wet.
    EDIT: The link I provided is close to the valve I have - I was being lazy. Here is the valve that I really have and you can get it at a pool store....http://www.familyleisure.com/Discoun...Way-Ball-Valve
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    What were you using to shut it off with your old skimmer? If you have an Intex valve, just move it to the other end of the hose where it attaches to the pump, like this:
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2014
    206
    I set up the pool and added hayward skimmer a month ago, didnt use the intex skimmer at all.
    What size is the intex hose for 635T and the Hayward skimmer "barb" i guess its called? Sucks HD or lowes dont make it easy...or well Intex LOL
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    It looks like it just uses the regular Intex 1.5 inch accessory hose like this one I got at Academy: http://m.academy.com/shop/Product_10...x+hose&Ntk=All
    One end screws directly to my Intex valve, with the other pushed onto the tapered Hayward adapter and then I secured it with a hose clamp.
    Pentair IC40 SWG
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    BTW, your 16" Intex Ultra frame should have come with the same shutoff valves. Mine did, and I have the very same pool.
    Pentair IC40 SWG
    Jun 2014
    206
    It did but it's on a inlet I'm not using as that hose now goes to the skimmer
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    It might be easier and cheaper to find a cap to close off the old skimmer hole as I did in the pic above, freeing up your valve to be used to close off the line to the pump, versus trying to find a new valve and adapter to fit.
    Pentair IC40 SWG
    Jun 2014
    206
    I thought it would be easier ugh, this person used a Hayward valve I believe uploadfromtaptalk1406317742918.jpg
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    They used this adapter but I have the 1.5" hoses. I think those are 1.25
    http://www.doheny.com/poolsupplies/I...reative=8-9718
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    DigbyAllen's Avatar
    Westchester, NY
    113
    Quote Originally Posted by Slammed01 View Post
    That photo you posted is my pool, from another thread. Yes, that is a Hayward ball valve. The hoses are Intex 1.5". They came with my 2650 sand filter. The adapters I bought from Doheny's allows me to connect the Hayward skimmer to the Intex hoses. It's working perfectly.
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
    Jun 2014
    206
    I think I'll order those then, where did u get the ball valve from? Thank you as well
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Quote Originally Posted by DigbyAllen View Post
    Is this the same ball valve your running? This and the linked above adapters is all that's needed?
    http://www.poolsupplyworld.com/Haywa...ve/SP0722S.htm
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    I have the same skimmer and added mine like this...
    http://www.troublefreepool.com/threa...404#post647404
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    DigbyAllen's Avatar
    Westchester, NY
    113
    This is exactly what I bought from Amazon. Hayward SP0723 Trimline 2-Way Ball Valve, 1-1/2-Inch FIP Pipe
    You're very welcome.
    Jim
    DigbyAllen's Avatar
    Westchester, NY
    113
    It looks the same but has a different model number SP0722S vs. SP0723. From the descriptions on Amazon, the one I bought (723) is FIP pipe and the 722 is SKT pipe. I have no idea what that means or what the difference is. Maybe a PVC expert can offer some advice.
    Jim
  20. Back To Top    #20
    Jun 2014
    206
    Nice! That was my next question haha, I'll Def get the 23 then! It all threaded together I see, I'll use some sealant and switch my Intex hose with clamp jammed on the bottom of my skimmer!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
