- May 31, 2012
- 854
- Vinyl
- Jandy Aquapure 1400
If you look on Youtube you will see some videos on how to use either burning glue or a torch to soften up PVC pipe to remove it from a collar. You then use a screwdriver and pliers to get the softened pipe piece out.
Anyone have any advice on how hard this is and whether you are better off using the glue or torch method.
I need to do this, or something similar to replace a Jandy 1400 salt cell as the newer units have different sized unions - see this thread for more: http://www.troublefreepool.com/thre...-Aquapure-1400?p=706288&viewfull=1#post706288
