I need advice on how i should plumb in a salt cell on existing equipment.
The salt cell is an aquarite t-15 cell which measures about 15" long and has a separate flow sensor built into a Tee-fitting
I was thinking about putting the flow sensor on the pool return side further into the plumbing to avoid generating chlorine when running the spa.
Also my search has turned up mixed results about whether to put a check valve in. What would you do with my particular setup?
