Results 1 to 13 of 13
Thread: Differences between FC/CC test and K-1000
    May 2011
    Orlando, Fl
    36
    I have used the Quick tester of the k-1000 and i get between .5 and 1 on the test but when i use the FC test in my main kit with the Powder, I get 11.5 on my FC and .5 on my CC.
    Why do i get the conflicting test measurements? And why are the so vastly different?
    Which one can i trust. The other day when the FC was O and the test said 0 the were in unison.
    20K gal Cartridge Filter IG Pool Plaster 1hp pump
    38,235
    Re: Differences between FC/CC test and K-1000
    Is the color matching test (the non FAS-DPD test) you are doing yellow or pink?
    The FAS-DPD is the one to trust, but I am potentially puzzled by what you said if it is truly the K-1000 with the yellow OTO chlorine test.
    May 2011
    Orlando, Fl
    36
    Im sorry, im using the Taylor TF-100 Using the R-870 Powder.
    I drop R-871 in there 23 times to turn it from pink to clear... then I use R-003 then R-871 to find the CC.
    My question is why does the Quick tester that comes in the Blue kit (K-1000) with Chlorine on one side and PH on the other show .5-1 CL BR and the FAS-DPD test show 11.5?
    38,235
    I was asking about the yellow OTO test.
    If the FC were 11.5ppm, then the OTO would be a dark yellow. So, I have no explanation for what you observed.
    The OTO is pretty bulletproof as far as telling you whether chlorine is present in the pool. But at the same time, the FAS-DPD is the most accurate ... one or the other tests must not be correct.
    May 2011
    Orlando, Fl
    36
    Im following the directions inside the lid on the FC/CC test. Could my Test Kit be bad its about 2 years old, but its only been stored inside.
    The color matching that i was doing is lightly yellow matching the .5 - 1 colors on one side and the PH is 7.8
    For chlorine/no chlorine trust the OTO test, but for exact numbers trust the FAS-DPD test.
    When doing the FAS-DPD test, how much water did you put in the vial? I'm assuming you used 10 ml?
    38,235
    2 years is pushing it, although I have had some of my reagents longer without issue.
    How pink is the water when you do the FAS-DPD test? Have you repeatedly gotten much higher results from the FAS-DPD than the OTO?
    May 2011
    Orlando, Fl
    36
    The water was a pink as the first time like cherry Koolaid.
    Yesterday i Got 0 on my FAS and 0 on the OTO... Chlorinated with a couple bags of shock and bleach since yesterday and now the OTO says .5-1 and the FAS says 11.5.
    on the 19th my CL was around 5-10 and when i did FAS it read 7ppm. SO that's why i was wondering why so different.
    Yes filled to 10ml
    May 2011
    Orlando, Fl
    36
    I'm reading the Extended Test Kit Directions and it Says for the
    OTO Chlorine Test
    TC - Total Chlorine
    Use R-0600 and i think i was using R-0003 Accidently... Time for a retest!
    They both had yellow tops and i think i got the switched around
    30,395
    Don't waste your time with 2 year old R-0600 reagent. It is somewhat light and heat sensitive and you have your money's worth.
    Save time and money and get a new bottle. I think you'll find the values will come closer together but that negates nothing stated in the posts above.
    May 2011
    Orlando, Fl
    36
    Using the Correct Reagent Confirms that the FAS-DPD test at 11.5 is correct. Thanks for all your help!
    38,235
    OOPS .... glad you got that straightened out. Keep the R-0600 in the blue box
    And I put the R0003 in the chlorine only vial for storage.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    ah ha!
    I bet thats it!
    Quote Originally Posted by Natesroom View Post
    OTO Chlorine Test
    TC - Total Chlorine
    Divin Dave,
