Thread: no chlorine
    Jun 2014
    rockport, maine
    4
    no chlorine
    I have been testing my pool water regularly, however, everytime I test it, its testing that there is NO chlorine in the pool. At first I thought maybe I needed to adjust the CYA as maybe there was none of that in it so it was burning off. But that is not the case, my CYA is where it is supposed to be. What could be causing it to burn off so quickly....do I need a different % of bleach, or is the 2cups+ that the pool math is calling for not enough?
    Help I am stumped!!!
    Nicole
    Intex 15x48 vinyl pool
    3776 gallons water
    new June 2014
    38,470
    Re: no chlorine
    Post up the test results.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: no chlorine
    Hi Nicole,
    it would be useful to have a set of test results. Also, what is the FC level you are trying to keep it at.
    It all ties together and its difficult to give advice without knowing the bigger picture.
    Quote Originally Posted by nicole View Post
    Nicole
    Divin Dave,
    Casey's Avatar
    SW PA
    10,453
    Re: no chlorine
    Without sounding like a broken record, we need test results. If you do not have a reliable kit, you can look at them here Test Kit Comparison.
