Results 1 to 18 of 18
Thread: Is my gauge right?
    Jun 2014
    Rogers, AR
    424
    Is my gauge right?
    Pool was filled yesterday and I am trying to learn equipment.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    38,281
    Re: Is my gauge right?
    Nope. Pool pumps will not generate that much pressure. Time for a new one. I highly recommend the glycerin filled ones that Dave is selling at tftestkits.net
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    If that gauge is right, you narrowly missed being killed by shrapnel when the filter body exploded.
    Jun 2014
    Rogers, AR
    424
    Thanks everyone! New one ordered from this site this morning.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Chrissykr View Post
    Good because that one is sideways
    Seriously though that is a good move .... after buying a couple cheapies i saw a thread about the good ones from this site and ordered one and it is far better built!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jun 2014
    Rogers, AR
    424
    My guage arrived today! Wonderful service I just ordered on Friday.
    Question...it has a big air pocket inside the guage is this normal?
    Smykowski's Avatar
    Sep 2011
    3,065
    That's how mine looks.
    Jun 2014
    Rogers, AR
    424
    Thnx, waves I just moved here five weeks ago from Bolingbrook.
    38,281
    Do not cut the rubber tip off, like it says. Although I think you want to pull the plug to allow the pressure to equalize and then put the plug back in.
    Many I see online have the big bubble. Mine is actually very full ... pretty sure it does not matter.
    Jun 2014
    Rogers, AR
    424
    I pulled the plug out and put it back in. Thnx
    Oct 2013
    Chapin, SC
    1,141
    I cut the tip as instructed. is there something bad about that?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,281
    If the glycerin is not leaking out, then should be fine. I am not sure why there is this confusion over the tip. The manufacturer said not to cut it and yet there is a note to do so somewhere.
    Oct 2013
    Chapin, SC
    1,141
    There was a small instruction sheet inside the box that showed to cut it. It's been so long ago-- no problem that I can tell. I would never have cut it without that instruction. Love the gauge!
    Jun 2014
    Rogers, AR
    424
    How do I know if my new guage is bad? It worked for the couple of weeks. I backwashed last Tuesday and the pressure went up one psi a few days after the backwash. A week later the pressure dropped back to the orginal pressure.
    38,281
    I doubt it would go bad this quickly. I would be more suspect of actual small variances in the flow rate and pressure due to outside factors.
    Jun 2014
    Rogers, AR
    424
    Ok, anything I should be watching for? Everything looks and sounds right.
    I can see the pressure not rising much over a week but the dropped worried me. I keep my pool sparkling and even my skimmer sock doesn't get much in it day to day.
    38,281
    The drop could happen from some debris collecting in your skimmer or pump basket.
    Jun 2014
    Rogers, AR
    424
    I had my filter deep cleaned yesterday and the guys were totally impressed with my gauge! They could not believe I paid less than $15.00 for it. They said that thing would would last through a bomb going off. This is the second time I have had the pool company comment on my guage. Thanks to TF test kits for offering such wonderful products at fair prices!
