Thread: Swg questions
    Jul 2014
    nottingham , UK
    24
    Swg questions
    I am looking at buying the intex swg. I am currently using stabilized chlorine granules and thats it. If I get a swg does it deal with everything or do I need to start adding stabilizer chemicals etc? Im in the UK so not sure on availability of seperate stabilizer etc over here.
    12' X 40" AG Pool - metal wall with liner
    Standard intex style pump/Filter
    2x 3kw heaters
    Surrounding decking area with hot tub and sauna inside a gazebo
    38,548
    Re: Swg questions
    If you have only been using chlorine granules, there is a good chance that your CYA is already too high.
    What do your test results say?
    All the SWG will do is add FC for you everyday. You will still need to be testing daily to dial in the SWG output and make sure the pH stays in range.
    Jul 2014
    nottingham , UK
    24
    Re: Swg questions
    The only thing I have to test is strips and they dont tell me cya. All its tells me is fc and ph. Fc is around 3ppm and ph is around 7.4
    2x 3kw heaters
    38,548
    Re: Swg questions
    Then you need a better test kit ... and not test strips which are garbage.
