Thread: help opening a 4600 gal pool without testing
    Jul 2014
    Anton, TX
    1
    We have just finished cleaning and draining our 4600 gallon above ground pool. It is almost full now. We have no way to get a test kit for another week. We have plenty of baking soda, bleach and borax on hand. Would someone please tell me how much to add of each. Thank you
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: help opening a 4600 gal pool without testing
    Welcome to TFP!
    Without test results, there is no way to know, and your pool will be green before the week is up without chlorine.
    You need to add about 1.5lbs of CYA (also called stabilizer) to protect your chlorine from the sun. Add it by putting it in an old sock in the flow of the return. Until you do that, I'd add a quart of bleach morning and evening to maintain chlorine in the pool. Once you have the stabilizer and it is all dissolved, you can just add the quart of bleach once a day until you get your test kit.
    That might get you by, but it's all guess work without a test kit.
    38,237
    Follow the Temp Pool Guide: http://www.troublefreepool.com/conte...emporary-pools
    Although you will have no way knowing the pH and will have to guess on the FC every day.
    Did you already order a test kit?
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Be sure to get that test kit ordered. I got the TF-100 XL with the speedstir. It is awesome.
    Trying to run a pool without a test kit is like driving through a parking lot with your eyes closed. There is a chance you will get where you want to go BUT it is not a very big chance. Keep reading POOL School and be ready to have the nicest pool on the block!
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
