Thread: Plumbing repair question
    Hey guys,
    I need to plumb in a bypass to temporarily replace the IC40 that is in my system due to one of the couplings breaking on Tuesday. The one thing I am curious about is do I need any special kind of pvc primer/solvent for the pvc pipe? Also...how long will I need to let it dry before I can turn on the pump? Our temps are in the upper 90s here and I am concerned about the water sitting stagnant for too long.
    Thanks!
    Scott
    38,271
    Re: Plumbing repair question
    If it is all PVC, then just use purple primer and PVC solvent. If some of it is CPVC, then you would need a universal solvent.
    Are you cutting out the IC40 unions all together? I though most of these were proprietary threads.
    I went 2 weeks in the AZ summer without a pump with no algae. Just maintain adequate FC and brush the pool to keep it mixed.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you in the future.
    I tried do the same and create a bypass for the IC40 but was defeated by the proprietary threads. I ended up buying the pricey Pentair 520588 Dummy Bypass Cell.
    Arizona. 22K Gal, IG, rectangular, plaster. SWCG IntelliChlor IC40. Pentair WhisperFlo 1.5 HP 2 speed
    Pentair Clean & Clear Plus 420 sq ft cartridge filters. in-floor. Pool completed April, 2008. K-2006.
