Thread: Server not found
    Jul 2012
    Whidbey Island, WA
    398
    Server not found
    Hi
    Server not found today with Safari and Chrome
    are there standard times when down for maintenance?
    same for tftestkits.net, sometimes Safari Chrome say unavailable
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Server not found
    When you suspect a problem, try http://www.downforeveryoneorjustme.com/ and enter the TFP address in the bar. It will help diagnose whether the problem is somewhere in your path or with the server itself.
    Just as a data point, I've never gotten a "Server not found" error from TFP.
    Jul 2012
    Whidbey Island, WA
    398
    thanks for the website, will bookmark it
    tried tftestkits.net and it said it is just me so will need to explore that
