Thread: swg circuit boards
    Jul 2014
    Fort Worth
    9
    swg circuit boards
    Just wanted to thank all of those who posted instructions and vids about fixing bad AQ-Rite boards by replacing current limiter. Did mine yesterday and is back up n running! I tried to replace the K1 relay also but couldn't get it off the board and decided to heck with it; will just put board back in with the new CL n see how it goes. a-ok for now. In meantime ill research a lil about how the heck to get that K1 relay replaced if it goes bad.
    Next on the list is researching how to find a leak. Did the bucket test last wknd; pool dropped 1.5 in. vs only 1/4 within bucket. Not finding obvious leak anywhere so far.
    Wife is off work today enjoying pool all to herself while im at work. no fair!
    22,542
    Re: swg circuit boards
    Glad you found out how to repair it yourself. Imagine of you hadn't found this info how much it'd have cost you. Not considering that you'd most likely thrown away a unit with just a minor issue.
    The DW and the GK's are enjoying ours today as I sit here slaving away!
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    Great timing. I just had the same issue and the fix worked for me too. Much better to spend less than $20 (including a soldering iron) to fix a $200 board.
    Once again this web site is a great resource for pool owners. Thanks again.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    38,248
    Johnl's Avatar
    May 2008
    88
    Great idea. I just submitted the payment. Thanks again for the forum and for the support.
    23K Gunite IG Pool
    Aquarite 40k SWG
    Polaris 360
