Results 1 to 11 of 11
Thread: Best way to Dispense the Stabilizer pucks?
    Jul 2014
    Syracuse, NY
    9
    OK so brand new pool owner. Read through the pool school. I just got done filling the pool. About to test it. I did buy some of the chemicals like borax powder, baking soda, and bleach. I also purchased a stabilizer in the form of 1 inch pucks. How is the best way to dispense this?
    Intex 18 42 6400gal AG pool
    Krystal Clear Filter Pump 1500gph
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Best way to Dispense the Stabilizer pucks?
    A feeder/floater designed for 1" pucks is best. Such as
    OR many other varieties available online, WalMart, pool stores etc.
    Isolated Spa - 345 Gallons
    I've never seen stabilizer sold in 1" pucks. Are you sure you didn't get stabilized chlorine tablets containing trichlor? We don't recommend using trichlor.
    Jul 2014
    Syracuse, NY
    9
    Quote Originally Posted by JasonLion View Post
    Yeah thats what I got..ill have to look around for the correct stuff. Since I just started a brand new pool my TC is less than 1ppm and have no CYA. I wont be able to get anything to bump my CYA until tomorrow is it still ok to add the bleach?
    If you haven't added *any* CYA, you want to add 2 ppm of chlorine each after dusk in the evening.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    yes, you can still add bleach. go to pool math and enter your information and shoot to keep you minimum free chlorine at 2 ppm.
    Handy Chlorine/CYA relationship chart
    Your pucks are adding CYA but slowly. Use pool math to figure out how much you need then pick up some HTH from wally-world. It will say 99% cyanuric acid. Shoot for CYA of 20 because you can add more next week if needed. Save the pucks for when you're gone on vacation.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Syracuse NY!? Hello from Fayetteville!
    So you know, East Syracuse and Cicero Walmart are out of stabilizer (CYA.) I got the last jug from E. Syracuse last week. Sorry. Another Walmart might still have some left. They won't restock until next season. Lowes is your next best bet (50% more money than Walmart), or a pool store (50% more $$ than Lowes). I know Lowes Cicero has a bunch of the 3lb jugs, as I got two last night.
    One good way to dispense is to pour into an old sock, and hang the sock in front of the return jet. I put my socks in the skimmer basket, although I don't know if that's an option on an Intex.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Jul 2014
    Syracuse, NY
    9
    Well that's not good. I'll make a trip to the Camillus wally world tonight. The only thing that home depot has was trichlor
    intex 18x42 AGB-Syracuse, NY
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Lowe's in Central New York has stabilizer. Home Depot does not.
    Jul 2014
    Syracuse, NY
    9
    picked up the last 2 containers of HTH stabilizer from Walmart in Camillus a few minutes ago. Say 96% Cyanuric Acid.
    Feb 2014
    Central Minnesota
    5,080
    HTH stablizer I've found is pretty good. Dissolves more readily than other brands of 99% CYA that I've purchased.
