Results 1 to 8 of 8
Thread: Filling the pool
    Jul 2014
    Paddock Lake
    1
    Filling the pool
    Our pool is being installed today! We have a well and use a softener because of the rust in our water. Is it ok to use the soften water or should we bypass it?? Thankyou in advance.
    38,548
    Re: Filling the pool
    Welcome to TFP!!!
    It is fine to use softened water, but I highly doubt your softener has the capacity to fill your pool in a reasonable amount of time.
    Jul 2014
    Northern Minnesota
    51
    I just went through this. We have a softner system as well. It regenerates every 1,000 gallons. Our pool is 3,284 gallons. We did the first 1,000 gallons with the well. It took a little over 2 hrs. Then we got a call from a trucking company who hauls water. For $150 they would fill the pool. We opted to drain the water in the pool (even though it went through the system it still wasn't 100% clear) and then had the whole pool filled by the trucking company. It was worth it. The pool was filled in about a half-hour, versus us doing 1,000 gallons in 2.5 hours, plus regeneration time of 1.5 hours, and back and forth....plus we didn't know the limit of our well, gallons per hour on our pump, and longevity of our pump. I'd go with the trucking company...but that's just me.
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    May 2014
    Owen Sound, ON
    44
    We went with trucked in water. Our well water is not clear, even with a PreFilter.
    Casey's Avatar
    SW PA
    10,461
    Welcome! Post pics when complete! Also fill out your signature with your pool specs as outlined here What we need to know to answer your questions.
    If your water's like the water here in Burlington I'd definitely truck in at least some of it.
    I'd say truck it. But if you want to fill it yourself bypass softener, there must be a bypass valves. I filled about 13,000 gallons from water well, but did it gradually over several weeks as I was worrying about pump burning or well drying out.
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    We filled with the well, bypassed the softener and dealt with the iron by adding a sequestrant. Then added 1 lb of shock and several oz. of clarifier. Water went from green tint but clear to sparkling blue over night. I have 1 puck in the floater and have added some acid to lower ph. I'm using a generic 5 step test kit and strips initially but will order a proper kit and intend to follow the TFP method.
    Deck is next. Pics soon.
    Mike
    P.s. Hi honey!
    Mike F.
    15' Above Ground Sharkline Matrix, Vinyl, 6,000 gal. Hayward XStream Cartridge Filter. TFT 50 Test Kit. Install 7/2014
    Raypack 150k BTU Natural Gas Heater installed 6-2016
