Results 1 to 7 of 7
Thread: does cloudy = night for chlorine departure and Ok to add chlorine / acid together
    Jul 2012
    Whidbey Island, WA
    397
    I understand should add chlorine in the evening so works all night before daytime sunny burn off
    lots of cloudy weather out here and is convenient to check pool in the AM before kids get in and add stuff if needed
    so is chlorine burn off any different daytime cloudy from night time
    i.e. should I change to evening schedule?
    TFP search did not return anything
    and
    seems I add bleach, pH goes up, add acid; repeat
    anything wrong with adding bleach & acid at the same time?
    TFP search says from 2009 add one, wait a few minutes for it to mix, then add the other
    still valid?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    38,305
    Re: does cloudy = night for chlorine departure and Ok to add chlorine / acid together
    You can add the chlorine whenever it is convenient ... but you should try to be consistent to learn your pools needs. The time of day does not really matter very much.
    You should test the pH and FC at the same time and then adjust both (leaving at least a few minutes between the additions so they mix separately in the water). The bleach will temporarily raise the pH, but it will drop as it is consumed.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I think UV radiation passes through clouds, so cloudy is not the same as night time.
    Regarding time of day to add chlorine, I like to add it in the evening so that FC is at its highest all night long. Adding it in the morning would have FC at its lowest level all night long.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Likelytheswimming and spkasing is the reason for the PH increase. If your TA is high it would also come into play.
    Jul 2012
    Whidbey Island, WA
    397
    I guess lotsa ways to skin the cat, at least this cat
    not much swimming splashing as grand babies not about
    TA is 70
    I can change to add in the evening
    thank you
    30,424
    +1 what jblizzle said. don't overthink the pool stuff.....it's all about repeatability and not worrying about minutiae.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I prefer to test/add in the evening due to the FC being higher for longer periods overnight rather than like mentioned earlier where it would be lowest overnight. But life is life and sometimes morning is when I have time.
    30 minutes with circulation between adding different types of chemicals is recommended. In a pool your size, like mine, I've added liquid acid at one end of the pool and added bleach at the other end of the pool within 10 minutes of each other but safer and more effective to give each chemical time to mix.
    Isolated Spa - 345 Gallons
