Thread: Yellow walls are back with a vengeance!
    Jan 2014
    The Woodlands, TX
    67
    Apparently I was not successful with my first mustard algae SLAM last month.
    Quick question....
    Is there any reason I cannot go straight to M.A. SLAM level instead of doing a normal SLAM first?
    Brad
    15,000 gallon IG plaster with attached spa. Full Pentair EasyTouch system. IC40 SWG. TFT-100
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Yellow walls are back with a vengeance!
    Normal SLAM instructions have been tweaked over the years to give the best algae-killing without bleaching the pool.
    Chlorine loss is a percentage of starting chlorine levels, you lose more chlorine going straight to M.A. SLAM levels.
    The recommendation is to do a normal SLAM until you pass all 3 criteria before taking the pool to M.A. levels for 24 hours.
    Jan 2014
    The Woodlands, TX
    67
    Is it possible for me to be having just a .5 FC loss on the overnight chlorine loss test when I have what I believe to be mustard algae?
    I have yellow on my walls if I go a day without brushing them. My steps have significant yellow/brown clouds when I sweep them every day. It's got to be algae, right? If it were pollen, it wouldn't collect on the walls, correct? The pollen season is long over here in Houston.
    I went from 6.0 FC to 5.5 overnight. No CC.
    CYA - 45
    TA - 180
    Brad
    Diver's Avatar
    May 2011
    South of Boston
    450
    I've been having greenish-yellowish spots here and there for quite a while as well. I just finished doing MA SLAMing and the levels are still coming down and so far everything is clear.
    I also had a negligible FC loss during the spots appearance. With a solar cover on 80% of the pool, I would sometimes lose only 0.5ppm per 24 hours even though I had visual signs of algae. The spots might be attributed to poor circulation, but I would think it would still show up on the daily FF loss.
    The time line of shocking is also interesting:
    8:00 pm - starting shocking, initial FC 7.5, target FC (calculated) - 24.7
    9:30pm - FC: 23 (1.7 loss, some of it might still be due to UV, some to organics, the estimated 24.7 might be off a bit due to water level, etc)
    6:00am - FC: 22.5 (0.5 loss, sun was partially out already), CC:0
    So I basically passed the OCLT right away and started MA SLAMing the same morning.
    So I would have clear water, no CC, minimal FC loss and some visible green-yellow spots..
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Low levels of mustard algae can sneak past the overnight FC loss test. Once it gets going the chlorine loss will be obvious.
