Results 1 to 12 of 12
Thread: What is this?
    Jun 2014
    Rogers, AR
    424
    What is this?
    New pool owner, i have everything pretty much figured out I but I am not sure what this is?
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    38,274
    Re: What is this?
    Looks like a cover for a wall suction line ... waterfall?
    Jun 2014
    Rogers, AR
    424
    Re: What is this?
    Ahh..I bet your right. I bought a foreclosure and I called the sticker on the equipment and they built the pool. They said it had a fountain. The former homeowner may have taken it.
    Is it only for a fountain or waterfall?
    happyheathen's Avatar
    Sacramento CA
    225
    Re: What is this?
    Did the builder have any recommendation as to what to do with the remaining bit?
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    38,274
    Re: What is this?
    I found a port (without a cover) for when there apparently used to be a separate pump for my waterfall. I plumbed it to the main pump and now can use it as a second suction line.
    I keep meaning to try to find a cover for it ... this is the first time I have actually seen it done. I need to find a similar one, ideally dark grey
    Jun 2014
    Rogers, AR
    424
    Re: What is this?
    No they just said there was a fountain.
    Sacramento CA
    225
    Re: What is this?
    Hate to appear Duh..., but:
    Is there some reason an ordinary drain cover wouldn't work?
    A quick Google came up with this (never heard of the company, either):
    http://www.electricmotorwarehouse.co...rain_cover.htm
    This has 4 models with flow rates for both floor and wall returns.
    One has 100 gpm rating for wall application; 180 for floor install.
    Dave
    Sacramento
    Jun 2014
    Rogers, AR
    424
    Re: What is this?
    I had my pool closed this week. I used the company that built the pool. It is a separate line from the returns and they said it is hooked to the main drain and when that gets plugged this line kicks in. Does this sound like something that is feasible? They also told me it is an exclusive design of theirs and that they are the company that came up with in floor cleaners design that all pool companies are using. I don't know if the are full of BS or not.
    New Brunswick Canada
    819
    Re: What is this?
    You can get those covers from any company that sells spa parts.
    Weird...if skimmer and main drain were plugged, this line would have any where to draw water from?
    Jun 2014
    Rogers, AR
    424
    Re: What is this?
    I am trying to understand how everything works so I know my pool. So I have no idea how it would work.
    819
    Re: What is this?
    It could be a suction relief system. Shoud anyone get hair trapped in main then the pressure opens a valve and water now comes from side port. Suctions ceases in main drain then.
    Jun 2014
    Rogers, AR
    424
    Re: What is this?
    Quote Originally Posted by pooladdict View Post
    That makes sense. I will go study up.
