Results 1 to 17 of 17
Thread: The Pool Cleaner no longer climbs the sides? Is this true?
    I just converted from pressure to suction and was about to purchase The Pool Cleaner, but came across this video which says they were just redesigned (Next Generation) and no longer climb the sides. Anybody know about this? Hate to be new design that is untested, since I'm basing my decision on reviews of the current product.
    https://www.youtube.com/watch?v=Md04D6fgESQ
    Thanks!
    38,248
    Re: The Pool Cleaner no longer climbs the sides? Is this true?
    Uh Oh ... so Hayward buys the company and everyone's fears may be coming true ... Did they really screw up the design?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I never quite understood why it climbed the wall in the first place. The cleaner doesn't scrub the wall so why bother? IMHO, vacuuming the wall does very little and it does not really substitute for brushing. For me, the most useful part of the cleaner is that it effectively removes debris from the bottom of the pool.
    Mark
    38,248
    You know, Mark, that is an excellent point. There are no brushes so it is not scrubbing anything anyway
    Well I often get slugs hanging out around the top of my pool after a rain. My polaris gets them (not sure if it gets them itself or it's tail knocks them off, but it gets them). If this isn't climbing, it won't. Slugs is my #1 reason for loving a cleaner!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Corry's slug bait works wonders! That way they never make it to the pool.
    But even with the old version, it rarely makes it to the water line. And when it does, it usually goes above it and sucks a lot of air so I don't think was very useful and probably wouldn't get the slugs.
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I wish mine climbed better. It spends half of its time stuck at the base of the wall.
    mas985's Avatar
    Pleasanton, CA
    11,737
    But why do you wish it climbed better? What do you think it would do?
    Mark
    Is there another pool cleaner that will get them? We already had the system switched from pressure to suction so I need to get something.
    And yes, I use snail bait. But I have vacation renters here half the year and there's nobody else to kill the slugs, so they build up. I don't want them dealing with slugs either.
    SW Indiana
    9,198
    Quote Originally Posted by mas985 View Post
    Anything but sitting at the bottom of the wall. It gets stuck, then bumps the wall when it tries to turn and goes right back into the wall.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by qofmiwok View Post
    You really don't want a suction cleaner to go above the water line or it will suck air and then the pump could lose prime and may not re-prime on it's own and then you could have a pump run dry which is a much bigger problem.
    You might want to consider a robotic. It has scrubbers which WILL scrub the walls and probably do a better job of capturing the slugs. Plus it is completely independent of the pump. But the renters will still have to deal with the cleaner.
    Mark
    Jun 2014
    860
    I have a Pentair KreepyKrauly SandShark. Works fine for me and it climbs the PebbleTec walls. Depending on how much your pump SUCKS (Hahahahaha, I crack me up...) it can easily jump above the water line (not good in my opinion). But overall I like it
    As far as snails go....yuck, not sure I want go fishing anything like that out of my leaf trap
    I have had good luck with the Hayward one. Change the pads and flaps ever 1.5 to 2 years. Climbs to the water line just fine. When it stops moving as fast change out the turbine. Both replacement parts are cheap.
    Sent from the bat phone near a drilling rig.
    [QUOTE=tbsimmons;706480]I have had good luck with the Hayward one. Change the pads and flaps ever 1.5 to 2 years. Climbs to the water line just fine. When it stops moving as fast change out the turbine. Both replacement parts are cheap.
    I'm not sure how your response is relevant, as they JUST made the change to the Next Gen. If you've had yours over 1.5-2 years then you have the old design.
    FYI, here is the response from hayward: "We have made minor modifications on the new cleaner. The Next Generation Models have wheel bearings instead of wheel bushings: plastic clip on wheel instead of shoulder bolt: Angle lower body instead of non-angle lower body: changeable inlets instead of fix inlet:axle inserts instead of brass or s/s inserts.
    Other than those modifications it will still work as the original PoolCleaner. The PoolCleaner can climb up the walls. They might go up to 2 feet before it comes down. The type of surface your pool has will play a factor of how the PoolCleaner climbs. It is not necessary for the PoolCleaner to climb the walls."
    [QUOTE=qofmiwok;708656]
    Quote Originally Posted by tbsimmons View Post
    Very easy relevant, my neighbor just bought one a few weeks ago (because he didnt fell like rebuilding it) I took it apart. The bearings, pads and flippers look identical to mine and the extra set I have in my shed.
    Both had ball bearings and I stopped there. The body looked a little different but thats it for what I saw as differences.
    Also my cleaner or my neighbors will not climb the wall if the suction is not set right. Too much suction and it wears the pads and flippers to fast, not enough wont climb the walls. use the little suction indicator that comes with it.
    Is that relevant enough for you.
    I dont believe the hype on a lot of "changes" companies make untill I can see for my self. A lot is so you buy a new one. Spending 12 dollars in flippers and pads every 1-2 years instead of a new cleaner, they need to do something to stay in business.
    SW Indiana
    9,198
    [QUOTE=tbsimmons;708675]
    This thread is about "The Pool Cleaner", a wheeled cleaner with an admittedly confusing name, so your post is really not relevant.
    [QUOTE=JohnT;708679]
    I took the post as asking for opinions. He saw a video and was asking if they climbed walls. I gave my opinion on mine as it climbs the walls if you maintain them. I didn't think the basis was just for one type of "Pool Cleaner".
