Thread: Those of you with a pool heater
    linda1's Avatar
    Mar 2010
    Western Pa.
    297
    do you set it to a temperature and leave it. Or do you just turn on when you think you might want to swim? We have been turning it on when we feel we will be using the pool. Of course with the Western Pa weather, we can have it on for 6 hours in the hopes of swimming in the evening and then a thunder storm whips up and all that gas was wasted. I wondered if it would be more efficient to set the temperature and let it keep it there. Would that use more gas?
    We have have a gas well on our property so it doesn't cost us anything, but we still try to be resourceful with it.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    38,262
    Re: Those of you with a pool heater
    Pretty sure you would use more gas if you try to maintain it at a higher temperature, especially if you do not use a cover. But, if having to wait so long is preventing from enjoying the pool and given the price of your gas ....
    Donldson's Avatar
    NW Ohio
    2,888
    You could always compromise and keep the temp just high enough so it only takes an hour or two to reach your desired temperature. If you are using it everyday, though, then keeping it at swimming temperature makes sense.
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Think about heating a house without a roof it's the same with a pool if you're not using a cover.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    +1 to using a cover. That will go along way at helping maintain the water temp overnight. 😎
    Jeff
    linda1's Avatar
    Mar 2010
    Western Pa.
    297
    I have the solar cover on anytime that we aren't in the pool. It's a pain, but I realize how much it helps in retaining the heat.
